17x9s on a '00 TL?
Old Apr 4, 2002 | 04:18 PM
KCMC582's Avatar
6th Gear
17x9s on a '00 TL?
I have 17x9s that I was gonna use on my 3000GT but now that I should be getting a TL, I dont wanna give up the rims. Is there any way these will fit with minimal to no rubbing? They will probbaly use a 255 tire. What do you guys think?
Old Apr 4, 2002 | 05:20 PM
StanMan's Avatar
probably not, but why don't you tell us the offset anyways...
Old Apr 4, 2002 | 06:38 PM
KCMC582's Avatar
6th Gear
i dont know the offest, the wheels are at my other house, i gotta take a look and see. where would it be on the wheel? on the inside right?
Old Apr 4, 2002 | 09:00 PM
StanMan's Avatar
yes it should be stamped on the back of the wheel face...you might have a sticker on the inner cylinder.
Old Apr 4, 2002 | 09:06 PM
NSXNEXT's Avatar
Looks like the bolt pattern is correct, 5x114.3.
Best bet is to pop one on the car and see, but I'd be pretty sure they won't fit. Too wide and probably too low an offset.
Old Apr 4, 2002 | 09:08 PM
Mr Hyde's Avatar
No one on this board has gone successfully with anything wider than 8 inches; I doubt they'll fit
Old Apr 5, 2002 | 12:58 AM
Lawaia's Avatar
Moderator Alumnus
Ahemmm...let's not forgot those that are running 20 x 8.5
Old Apr 5, 2002 | 10:06 AM
don't lower it put on a larger rim.
Old Apr 5, 2002 | 09:12 PM
KCMC582's Avatar
6th Gear
lawaia, you are running 20 x 8.5s without any rubbing? i might have a little bit of hope if you can do it without rubbing. the guys at tirerack.com said no, but i dunno...
Old Apr 6, 2002 | 01:06 AM
TommyBoiSxty9's Avatar
doubt it
Old Apr 6, 2002 | 03:17 AM
Lawaia's Avatar
Moderator Alumnus
Originally posted by TommyBoiSxty9
doubt it
Geez Tommy...so negative, that's not like you.
kcmc...No I'm not running 20's...my earlier comment was sarcastic....couldn't you tell.
Old Apr 6, 2002 | 08:20 AM
KCMC582's Avatar
6th Gear
damn, well, it looks like my rims aregona go up for sale then. oh well, thanks for the help guys.
Old Apr 8, 2002 | 03:37 PM
TypeSDragon's Avatar
Loving my 08 TLS!
Hey don't I know you?? Are you Casey from the H-A net board. This is Vtecdragon if you remember. You thinking of buying a TL, boy? Good choice! But then again, the 3000GT is not bad either.
Old Apr 10, 2002 | 06:31 PM
Red Hot TL's Avatar
nope, they shouldn't fit. I have 17 by 9's on my Z, and the bolt pattern is the same, but I tried fitting it on the TL and they're just too wide.
lumyeinjun
115
Sep 26, 2025 03:46 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
az05tsx
May 28, 2013 04:39 PM
cl9leo
Jan 27, 2011 08:45 PM
invincible569
Oct 4, 2005 06:45 PM
