07 TL S ... 19x8.5 front 28 offset to far out? HELP
I have a good deal on Linea Corse Dynas but the only size this guy has is 19x8.5 in front with a 28 offset? Anyone have any input? 235/35 tire?
Rear is 19x10 43 offset. NOT WORRIED AS much as the front? Doing a Eibach pro kit with Koni SP3.
Looking for advice??
No bolt pattern 114.3. I just used that photo cause those are the same wheel type and look/finish and that picture sold me on this wheel design.
I know its aggressive but I figured if 35 is good 28 isn't far of a stretch.. I was told it will clear but only questionable factor is if it will stick out to much. I dont want to be kicking up road debree if you know what I mean. Its 43 in the rear so I am not worried about that. 19x10
i was under the impression they coming off M3...
Could go either way... Here is a picture when I was test fitting 8" wide rims with a +30mm offset. You can see that it is perfectly flush with the fender. Depending on your wheels style, it could be flush, or it could stick out past the fenders...
235/35 in front and 265/30 in the rear. According to wheel dude who I ordered them from, those are going to fit with fender roll in rear only.
UH OH we will find out next week. Combo'd with Koni Shocks and Eibach Pro Kit. Any idea where to adjust Konis for best ride comfort without being bouncy?
According to WheelDude who more than likely has zero knowledge/experience with Acura TL fitment...
Why didn't you just listen to people who actually have knowledge/experience with the TL and get the 225s in the front? With the 235s you're probably going to rub. But since you're getting the rears rolled anyway you can get the fronts done too.
LMAO... that was pretty funny. Shit well unfortunately they shipped already with those sizes! I guess Im going to live with them as of now. I thought 225 was stretching them a bit to much. Anyway, Ill either have to make it work... or ill swap tires if its to much of a pain!
i feel like 235 is in between and possibly not that much ?@?@ am i dreaming!! FUCK lol i hope I don't have to change to 225 that will be another 300$ in tires. Well find out i had them mounted and ready to go so i cant take them off
I'm running 8.5" wide wheels with +30 offset and I have enough room that a +28 could fit without issue. I'm also running 235's. No funder rolls, dropped on Tein SS about 1.75" in the front, no rub!
Can it matter that they're 18" though?
Ya I think so. IM going to be close. Im not doing an aggresive drop. 1inch with Eibach Pro Kit. The Konis may set it a little lower. I might have to switch to 225. Or Just roll the fenders and call it a day. I think Ill be fine but then when I have 4 people in the car Ill notice.
DunesCreations
09-09-2015 12:03 PM
nuldabz
09-03-2015 05:49 PM
