Wrap rotor?
Wrap rotor?
Does anyone have any problem on OEM rotor on type S which is made by brembo? My steering wheel starts shaking when I brake. The rotors are brand new only 3 months old. Is it the problem with the rotors? Thanks
Plastidip it to wrap it.....
Prob didnt bed the new rotors in with new brakes....my
do you even bed in bro?
#1 - If you don't understand their question about bedding in the pads/rotors, you may want to read up on that.
#2 - Only a few things will "warp" a rotor and most of the time, it isn't actually warped.
-- Improper bedding or uneven transfer of pad material to the rotors
-- Warped rotor due to heat cycling -- less likely unless uber hot and doused in water
-- Warped rotor due to improper lug torque
"Many" times, you can attempt to re-bed the existing pads on the existing rotors and possibly get things back to normal. There are a lot of threads on there that lay out this process...but the basics are use the brakes, get them hot as a mofo, and then keep driving to let things cool back down.
May have to machine them before bedding again. Or just buy new ones
Live and learn.
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
