wow 04 tl won't start HELP!!!!!!
Old Dec 11, 2007 | 09:20 PM
silveracid's Avatar
from night to day my tl will turn over but will not start i checked all my fuses all good and my fuel pump is working just will not start Help .....HELP!!!!!!
and just filled up the tank with gas
Old Dec 11, 2007 | 09:37 PM
csmeance's Avatar
Check the battery, it should be giving out 550 Cold Crank Amps. Also it should be a 12 volts. If the battery checks out, it is probably water or bad gas in the tank. It would require the tank to be drained and the filled with the proper fuel. Which station did you go to and how long after the fill up did it not start. Also did it start at the gas station? Did it run a bit rough after filling up?
Old Dec 11, 2007 | 09:45 PM
silveracid's Avatar
naw that is the crazy part it ran all day yesterday and i just put a new battery in it bout 2 weeks ago i put shell vpower but it ran fine the only thing i did differ was i used fob memory #2
Old Dec 11, 2007 | 10:36 PM
csmeance's Avatar
does the car try to start? Check to see if there is a green flashing indicator on the gauge cluster, kinda like a blinking key. If so, then the Immobilizer chip is not programmed to the car, take it to acura and tell them that your original key does not work. If not, then check and make sure that the terminals on the battery are still attached and not loose or corroded. Check the battery and report back, a new battery could have bad cells in it. I wouldn't rule out gas as there could be sand or something blocking the flow from a dirty tank at the station.
Old Dec 12, 2007 | 08:00 PM
silveracid's Avatar
Immobilizer chip ???? well i have a blinking green but only after i turn the key twice
Old Dec 12, 2007 | 08:04 PM
silveracid's Avatar
and the other thing i think is weird my check engine light is not on
Old Dec 12, 2007 | 09:27 PM
BLACKURA_NY's Avatar
I have car ADD
green "key" light is flashing ??
try your other key... could be the key #2 wasnt programmed right
Old Dec 12, 2007 | 09:37 PM
silveracid's Avatar
its both keys
Old Dec 12, 2007 | 09:50 PM
I have car ADD
maybe the bad #2 key fucked up your programming for the whole car/ or both keys
Old Dec 12, 2007 | 10:30 PM
csmeance's Avatar
I think that the immoblizer unit may have gone bad. If the car is under warranty, call acura, schedule an appt. with a loaner at their earliest time and have the car towed there by acura TLC
Old Dec 18, 2007 | 10:52 AM
silveracid's Avatar
well i took it in to a honda service center the acura service center is about 167 miles away and i think that was a mistake they fixed the car by reseting the ECM codes and changed my power steering belt so i was real happy till i took the car home and found out that my power mirrors did'nt work then to my surprise i found that my ac/heater/seat heaters/mirrors heater/temp reader/all did not work....i called honda and told them they said to bring it back and now they are trying to make me pay for it cuz they said that what they did did not effect all of that ohh yea and they made me pay to reset my radio code
Old Dec 18, 2007 | 10:54 AM
silveracid's Avatar
what happened to customer service???????????
Feb 25, 2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
