Windshield Washer Problem
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Hi Guys,
So I am having a problem with my windshield washer fluid. At first I thought because it is very cold outside the fluid is freezing which is causing it not to work. However, I couldnt here the pump as I used to be able to when I pulled the stock back. I began to think it had something to do with the fuse being blown. I did a little searching on here and it seems to be a common problem that the wiper fluid pump fuse blowing on TLs however my rear view mirror was working as was my tilt function so I knew it wasnt the fuse. Randomly though when I pull the stock back the fluid comes onto the windshield now.
So I am not sure what the problem could be, has anyone had issues like this? Or direct me in a way I can trouble shoot some more?
Thanks for an insight anyone can provide.
i had same problem, was looking for bad fuses, because i didnt hear pump working. Didint find any bad fuses. I though that fluid frozed, but that was not the problem. Then what i did ,is just press and hold window whasher switch from minute to two minutes and it started to work again, never had same problem.
namisiz (01-07-2014)
B A N N E D
Hi Guys,
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
![Genius](https://acurazine.com/forums/images/smilies/genius.gif)
amazing
SidhuSaaB
05-30-2020 12:40 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
