Window won't roll up !!!
My passanger window keeps getting stuck alway then comes back down.. the only time i can get it up all the ways is when i push it up... any ideas that can cause it... i do have felt on the window when i got it tinted in nov but havent had an issue until now...
The following 2 users liked this post by Majofo:
glennjr15 (02-14-2017),
rockstar143 (05-13-2013)
Yea, i was thinking of just changing the whole felt.. but your idea sounds better... where can i get teh shin-etsu grease??
Yuuuup. There's a TSB for it, located in the 3G Garage...
TSB 10-014: (2004-2008 TL) Power Window Goes UP and REVERSES on it's Own, Is Slow to Open and Close, Or Squeals, Creaks, Clunks, or Clicks
http://techinfo.honda.com/rjanisis/pubs/SB/B10-014.pdf
Follow the instructions at the top of this page if you can't open the link.
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
Those links are locked by Honda and have been for the past year.
OP, this is what you want. The Honda PN is shown on the box:
You can order it from our acura vendor prestige or these sites:
handa-accessories.com
acuraoemparts.com
acuraoemparts.com
:shakehead No, AZ now has operable links and the ability to open the TSBs in https://acurazine.com/forums/showthread.php?t=613659 as long as you follow Ron A's instructions in red type at the top of the first post.
If all else fails, I'll copy and paste the instructions from the PDF for you.
Necromancer here
After getting my busted window replaced I now have this issue.
At first, it wouldn't roll back up at all; it went up a few inches then automatically back down again. After looking at it I saw the weather stripping at the bottom was getting caught/sucked under because there was an extra 1/2 inch on the end. I cut that extra part off and now it will roll up but only manually.. and it still goes noticeable slower than before or than the other windows. The auto roll still doesn't work even after doing the manual reset. I think the channel looks fine, still think the grease would help it or could it be the regulator in this case?
I'm thinking of just taking it back to the place that 'fixed' it.
I'd take it back, but try the lube...lube always helps.
Seriously, my windows would kick back down all the time...take some shin etsu (or white lithium if you're in a pinch) and put a dab on your pinkie and rub it in the whole back end of the channel, wipe off the excess, go up and down a few tires to it coats back edge of glass...
If you had "excess" though, something probably wasn't put back in correctly.
But they have the okay from Acura to replace, so they get to charge 2 hours labor! Sure, why not.
Glad you got it figured out, E An. Honestly, this car has about the most finicky electronic system ever...
The channel has been greased. WHAT NAO!? Thought so
I remember garthumpy had this problem a few years ago.. his regulator speed going down was 12.xx and going up was like 3.xx. So. I am just saying.
07-16-2017 08:33 AM
xsilverhawkx
09-28-2015 07:51 PM
