WINDOW issue (passenger)
Old Oct 3, 2008 | 09:49 AM
Sunnybwoy1's Avatar
So im having a issue with my passenger side window when i try to use the auto roll to go down it works fine but if i try to go up it goes half way then back down again it will only go up if i hold the switch half way then it will go up anyone every have this issue im thinking its the motor or some relay
Old Oct 3, 2008 | 09:35 PM
bdogg77's Avatar
mine does the same thing. There is a way to reset it, however, it may not be a perm fix. Manually roll the window down (do not use auto down) then manually roll window all the way up and continue to hold the button up for 3-5 seconds. This will sometimes work but only temp for me. Good luck.
Old Oct 5, 2008 | 04:11 PM
narnia's Avatar
Team SSM Queen
Same thing just happened to my '04 this week. I rolled it back up after a few tries, now I'm afraid to open it again because I don't want it stuck in the open position.
tman570
Jun 11, 2019 07:56 AM
justin7779
Dec 25, 2015 10:33 PM
Aging-Hacker
Oct 5, 2015 11:44 AM
acuraST
Sep 17, 2015 02:31 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
