window and front seat wont work
2011 ZCP E92 M3!!
my front passanger seat wont move or anything and also the airbag lite is on and also the rear passager side window dosnt work either sumtimes it works and sumtimes it dosnt but i dont know how to fix it permantly and why are they connect cuz they both go out at the same time and come on at the same time too....im lost i think it might be loose wires
2011 ZCP E92 M3!!
guys i need help now asap....My window wont go up and its like 10 degrees here what can i do im trying to force it up and i wont go all the way its half way down...i have cardborad over it now...but i wanna fix it i took it sumwhere and they cudnt find the problem...anybody know anywhere in queens newyork where i can get it fix?...what would it cost if i go to the dealer....my car is a 05 and 49000 miles...will it still have warenty?
the power for my front passanger seat is out too...its the same prob;em like b4 its on and off...but right now its not coming back on...it has to be sumthing with the wires under the seat
For the power seat, check fuse 6,7,14, 16 in the left kick panel fusebox. Also check fuses 15 and 20 in the underhood fuse box.
Do your other windows work?
2011 ZCP E92 M3!!
yeah everything elses works fine its only that 1 window and my passanger seat....and i dont really know how to check fuses can u help me out...i was just planing to change all
Open the underhood fuse box and find the yellow fuse puller. Use that to pull the specified fuses from the left kick panel fuse box. (the cover of the fuse box has the diagram on the backside) At the top (colored transparent plastic) part of the fuse you can see a silver "V". If the "V" is not broken, then the fuse is good. If the fuse has blown, the "V" will be broken.
Check your #7 fuse first. That could solve both problems, however, if your navi still works, probably not.
For the window, it could be a fuse or a power control unit, window regulator or switch. Fuse is the easy fix. Other possible fuses for that window would be:
fuse 27 in the left kick panel or fuse 23 in the underhood fuse box:
2011 ZCP E92 M3!!
i dont think its window regulator or switch cuz it comes back on sumtimes i just wanna fix it permanet now..its all connected some how.....the seat the window and maybe the navi
2011 ZCP E92 M3!!
does anyone know how i can remove the back door panal to get to the window so i can put it up...i have an appointment with the dealer on monday to get it fix but for now i need it up cuz its cold and loud wen i drive
TYIA
TYIA
2011 ZCP E92 M3!!
i fixed it i found out the problem after going all the wrong routes...its some wires under the seat...the connoector is kinda lose or broken but i squeezed it togther and ran to the back and closed the window and its not working again but atleast its up ill take pics and show u guys later ...now i need to go find those connectors and chnage them
handsom-hustla
11-13-2015 05:04 PM
asahrts
09-04-2015 05:55 PM
