Wierd Noise
Old Oct 5, 2006 | 09:36 AM
Robert05's Avatar
Wierd Noise
Hey all - so I have been noticing over the past week or so a strange vibration or knocking noise comming from the front driverside of the engine. This noise ONLY occure when: the car is in Drive and the brake is fully depressed. ie: when stoped at a stop light idling.
Anyone have this issue? I was thinling it might be the CAI rubbing against something but the sound is not present when the car is in nutural, only when in drive.
The rest of the time the car works great and I have noticed absolutly no preformance issues associated with this sound. wierd eh.
Anyways thanks for any input...
Old Oct 10, 2006 | 12:41 PM
Robert05's Avatar
..bump
Old Oct 10, 2006 | 09:18 PM
Inaccurate's Avatar
I would go with your hunch. The engine is under a load while "in gear" versus while in nuetral. So, the engine would be slightly torqued (twisted) while in drive. This could be enough to cause the CAI tube to be pushed close to the car body to lightly vibrate against the body. WITH THE ENGINE *OFF*, examine the CAI tube as it snakes thru the body. If the tube has less than approx 1/4 inch clearance anywhere along it's length, this might be your problem. If so, then *CAREFULLY* examine this tight area while *SOMEONE* else is inside the car applying the brake while the engine is running.
Old Oct 11, 2006 | 10:03 AM
Robert05's Avatar
ha - I actually did just that last night and it is the CAI. Now to correct the problem.
thanks!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
