Why so serious?
9 mpg.
Why so serious?
Because I think my tranny's dying a slow death on me..
I recently did a drain of the stock Z1 ATF and re-filled it with 3qts of Redline D4 ATF. It shifts a lot smoother now. However, when the mechanic took my car for a drive before the drain he said that my second gear was "slipping", and when we drained the Z1, it was dark brown and kind of smelled burnt.
Now, after the D4 was put in the car is shifting a lot smoother, I can barely feel it actually. But after those guys mentioned the 2nd gear issue, I'm feeling kind of nervous about my transmission failing. Anything I should look at or monitor? I was talking to the manager at a local auto parts store and he said that if it's slipping, it could be the clutch packs.
did u only drain and refil 3 quarts? i've read that its bad to mix fluids.. so maybe try this to extend life of ur tranny? and have u seen the thread on replacing the 3rd and 4th gear sensors?
3x3 - https://acurazine.com/forums/showthr...&highlight=atf
3rd n 4th gear - https://acurazine.com/forums/showthr...&highlight=atf
Last edited by jwr0ng626; 09-22-2010 at 03:25 AM. Reason: adding 3rd n 4th gear link
I'm due for my transmission fluid change and am changing to the Redline. In the process, which should I and the OP do first, the gear sensor change or do we do the fluid first?
I'll probably be tackling this when I come back from vacation (or whenever the redline gets in!)
9 mpg.
9 mpg.
If I do the full 3x3, do you think my 2nd gear "slip" will go away? I need to keep this car for at least another two years and being a broke college student means I cannot afford a new transmission in any shape or form.
BANNED
i am switching out my 3rd/4th gear sensors and doing a full 3x3 drain n fill in the next few weeks as preventative maintenance, and to see how different the shifts feel after replacing the fluid. i'll be doing 6 qts of d4 & 3 qts of type-f. will probably be replacing the sensors first.
also seafoaming the intake, gas, and oil crankcase. then replacing the oil with redline 5w-30 and RP oil filter.
it was either this, or send JnC my headlights to be done. i'll wait on the headlights for now...
Have you actually felt it slipping? Or are you just going on the mechanics word?
9 mpg.
Also, I checked my ATF again today. It looks like I need to do the 3x3. The ATF smells though..I don't know if that's just how ATF smells when it's hot or if it's burnt.
The clunk is somewhat normal.
If it's slipping or even if it's not, skip the D4 and go straight to the "racing" fluid. D4 is good but you need the holding power of the racing fluid. You will be very glad you did.
Solenoids are a must too.
Skip the D4. Do 3x3 with RedLine Racing ATF and hope for the best
Compared to D4, the Racing fluid will provide substantially more grip to the clutches, or to the little bit of clutch that you have remaining.
At this point I only recommend the Racing. D4 is a good fluid but there's no point. "Racing" will do a better job in a turbo TL all the way to a bone stock TL that's driven easy. I know this sounds too bold but D4 and all DexIII based fluids are obsolete in our cars with the DBW.
BANNED
9 mpg.
Yes sir!
Sharks got you. VVV
I think you're mocking me.. hahaha
Yes sir!
Did you do a complete 3x3?
the trans holds over 7 qts, of which 3.sum is in the tq and the rest in various oil passages,
only 3.some will drain out at one time, then you refill and drive a short distance (5 minutes so it doesnt get too hot under the car to work and doesnt blend the fluids) using each gear including p r n and each d up and down
drain and refill
drive
drain and refill
repeat as needed until complete change of fluid is done,,thats more fluid than most of you guys are talking about
takes over 7 qts to move the old 7 old plus some safety margin to rid trapped old stuff
thats where 3x3 came in
going to redline,, I would want all the existing fluid stored in jugs when I get done~
Thats from a gen2 owner--the original trans prob cars
slipping as defined by acura is rpm goes up and car does not accellerate in reaction
Or slips means revs and wont grab the next gear--slams into gear compared to its former butter smooth operation
this prob show first at full throttle and progresses to even low to mid throttle will cause it
if its on 04 05 its got gen2 problems with the early clutchpack wearout and old style trans case
The clutch packs are a series of stacked friction disc, and the friction wears off them~
running a bunch of fluid thru it when already weak can wash away ~needed crud~
new fluid contains large amounts of cleaner... compared to whats in there now
drain and refill
drive
drain and refill
2nd and 3rd gear are the weak parts--AT cars avoid use of SS to downshift into those except when out playing,,,,
street use leave it alone and brake to slow
downshifting is to be in the right torque and rpm at the apex of the corner-
brakes are for slowing and stopping the car,,and cost a fraction of new trans~
9 mpg.
It's just sort of a rough shift from 2-3 most of the time. I'm gonna' do a 2x3 of the Redline Racing ATF in the next week or two and then switch out my solenoids with the pay-check after that hopefully.
9 mpg.
So wait a minute, IHC and 01TL04TL are confusing me. Should I finish off the 3x3 with the Redline Racing ATF like IHC says or leave it alone because "running a bunch of fluid thru it when already weak can wash away ~needed crud~
new fluid contains large amounts of cleaner... compared to whats in there now" according to 01tl04tl.
So, 2x3 with racing ATF and change out the solenoids or not? What else can I do?
You're not going to hurt the trans doing a 3x3. I only throw the warning to introduce new fluid slowly when the car has over 100,000 miles without a service and even then it's questionable.
If it were me I would do a 3x3 of the racing fluid to get mostly new fluid. It won't hurt a thing to do just a 1x3 or 2x3. You will notice a difference after only a 1x3.
If you're on a very tight budget I would do a 1x3 with the racing fluid and the solenoids. The solenoids will make as big of a difference as the racing fluid will. At a later time when you have more money to spend, go ahead and continue with a couple more 1x3s.
BANNED
9 mpg.
Just for clarity, I'm going to order enough racing ATF for a 2x3. I just did a 1x3 with the D4 ATF 2 weeks ago.
emailnatec
29
09-28-2018 04:27 PM
Ponsey_Scheme
10-23-2015 09:16 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
