Whistling noise from engine
Old Jul 21, 2009 | 12:49 PM
o4Komodo's Avatar
Rev High; Drive Happy
I just put in the P2R Intake Manifold spacer after several months....
However while putting it on I accidently snapped off the bolt for the Intake Manifold Cover.
Now that makes two snapped bolts in total on that cover.
After the install was finished I took it out for a drive. After filling up some gas I realized that there was a strange whistling sound coming from the engine.
When I'm under throttle the sound goes away... but once I let off the throttle or when I am idling the sound comes back.
Any ideas?
Old Jul 21, 2009 | 06:13 PM
mlassek's Avatar
Old Jul 22, 2009 | 12:42 AM
240sx acura tech's Avatar
acura master tech
well you snapped to bolts on the manny and need to replaced its letting air in .
Old Jul 22, 2009 | 05:26 AM
o4Komodo's Avatar
Yeah... I turned on the TL and let it idle.
The most recent bolt I snapped is now creating a type of vacuum where the bolt used to be [the stud of the bolt is still there].
The other bolt is more of a pain to fix though.. but has not caused any issues.
Old Jul 24, 2009 | 10:57 AM
Majofo's Avatar
Any ideas?
Duct tape!
jk.. definitely vac leak through your mani cover.. get new bolts & gasket!
Old Jul 24, 2009 | 03:33 PM
RACINGHART03's Avatar
^x2
Yikes
May 3, 2021 04:29 PM
Feb 25, 2020 09:57 AM
Frathora
Sep 28, 2015 11:29 PM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
