Whine Noise when starting Power steering?*
Old Nov 19, 2010 | 07:20 PM
henryrodriguez's Avatar
8th Gear
Exclamation Whine Noise when starting Power steering?*
When I start my car in the morning, and I turn my steering wheel just a bit. It makes this whine noise, and only if its cold outside. Im not sure if it's the pump. It's not the fluid I already checked. Any help would be very appreciative!
Old Nov 19, 2010 | 07:29 PM
I hate cars's Avatar
Do a search, there's a huge thread on this exact issue. It's an 0-ring.
Old Nov 20, 2010 | 09:59 AM
twenty5's Avatar
hot dayyyum. I was about to post a topic about this too. The season just got cold and mine does the EXACT same thing. Was starting to get worried. I'm happy someone said O-ring w/e that is cuz a fucking power steering pump is expensive for a 19r old dood LOl.
Old Nov 20, 2010 | 11:50 AM
el.profe's Avatar
its the O-ring. Its an easy and cheap fix if you do it yourself.
Old Dec 1, 2010 | 02:13 PM
ayanomich's Avatar
yep,it's the o-ring........had the same sound when starting in cold weather yesterday, took it to the dealer, still under warranty. the sound went away after driving for 30 minutes, but the dealer knew what the problem was because the power steering fluid had air in it. Replaced the o-ring in 15 minutes.....running fine, quiet again.
Old Dec 1, 2010 | 09:05 PM
8th Gear
YES! Thanks for all the replies!
Old Dec 1, 2010 | 09:53 PM
DooooT's Avatar
Sorry to thread jack OP....but is it common to have a "whine" noise when driving. This noise doesn't go away either after 30 mins. Today it was about 68 degrees F and the whine noise was exceptionally loud. Stops when the car is not moving.
Are we talking about the same noise or do I have another issue?
Any help>>>>>
Old Dec 1, 2010 | 09:57 PM
Any help>>>>>
The powersteering issue will be there anytime the engine is running regardless of road speed. Something else is wrong with yours. It can be a lot of things. Transmission comes to mind, so does a wheel bearing. You might start another thread on it to get more help from more people.
Old Feb 2, 2015 | 09:41 AM
SurfingScotty's Avatar
2007 6SMT Type-S
Hey guys, need some input:
I changed the O-ring on the inlet line with the factory o ring. Still whines until warm. Found out Acura sold me "the black ring", went back and got the "orange ring" that was recommended by the community. I still get the whine until warm. Suggestions?
Should I replace the high pressure o ring that is further up on the power steering hose/line?
Old Feb 3, 2015 | 09:31 PM
fijiisland11's Avatar
2008 TL-S
Had the same problem. Changed the old black o ring to a new orange one and it fixed the problem.
YouTube has many step by step videos that can help.
Old Feb 3, 2015 | 10:42 PM
DeathMetal's Avatar
Fearless DIY Guy
There are two predominantly crappy o-rings on the PS pump. The first and most common is the o-ring failure on the inlet joint (91345-RDA-A01). Once that's been replaced your inclination is correct - move upstream and replace the P/S Feed line o-ring (91370-SV4-000).
Also, examine the PS pump for any residual fluid on the pump casing - you may need a tear down and rebuild of the o-rings if the two aforementioned fixes don't do the trick.
Old Feb 4, 2015 | 08:02 AM
DeMAN's Avatar
Is there a recall on this item or a service notice?
TL-Rocket
Apr 29, 2023 02:33 AM
Feb 25, 2020 09:57 AM
mike from annapolis
May 7, 2017 08:21 PM
asahrts
Sep 4, 2015 05:55 PM
dlknight
Sep 3, 2015 07:54 PM
