Where's the starter cut relay ?
Having issues with starting the car (2007 A/T). Idiotically assumed it was the starter and then ignition. Replaced both. Battery is fine..Checked my connections for corrosion. After downloading the service manual..looks like starter relay is in a different spot than the video I watched .I just assumed all 3gs were the same . I can't find this..I assume it's under the hood . Thanks in advance
Are you sure it isn't your positive battery cable? I ask because many of us, myself included, have had problems starting our cars; the cable looked "good", but internally had failed. Replacing the cable, which costs between $40 and $50 from the online Acura parts dealers has solved the issue for many.
The photo you posted above is for 04-06 location, 07-08 locate behind the dash on driver side (sit on top of the main fuse box). What make you think its the relay that cause the issue? if you could describe the symptom that you having.
feynman314
03-09-2017 04:46 PM
ericv501
10-05-2012 01:54 PM
