07 acura tl tapping noise
Old Mar 20, 2021 | 05:22 PM
Ernestogl's Avatar
Question 07 acura tl tapping noise
recently I started hearing this inconsistent tapping noise from inside the car. after looking at videos I was convinced it could be valve noise but the noise is not consistent and it happens after the engine is warm and audible only on idle and very little when the hood is open. from the video I provided you can hear the noise suddenly start and then stop, after I increased the rpm a little and come back and then go away after turning on the AC and then suddenly come back up but a little louder. the noise is confusing because from the inside it sounds like it is coming from the engine, but when I listen from the outside and towards the back of the engine you can barely hear anything until you put your head really in there. any ideas what it could be? (07 Acura TL 3.2L)
Old Mar 21, 2021 | 07:43 AM
Turbonut's Avatar
Certainly difficult to pinpoint, but I'd start with removing the serpentine belt and see if the sound is still present.
There have been cases where the crank pulley splits and sounds like a rod knock.
Jared Stiers
Apr 19, 2021 01:36 PM
Moussa Harouna
ILX
May 14, 2019 08:21 AM
Skirmich
1/2G MDX (2001-2013)
Dec 16, 2016 12:24 PM
