When Ign key is turned, starter turns but will not disengage
Old 02-08-2010, 08:33 AM
dobroman2001's Avatar
Hello,
First time posting...
I started the wife's car this morning and when I turned the Ign key, the starter engaged but would not stop turning however it sounded like the car was trying to fire. I turned the key off and tried again with same results. I finally tried and just let it run and the car finally started running (really rough though) almost like it was flooded. Any ideas as to what would cause the Starter to stick? Is is a bad Starter or the Ign switch or something else? Thanks for any advice...
Tab,
Old 02-08-2010, 08:43 AM
nisreo's Avatar
could be either. After you start it, try wiggling the key and see if that makes a difference.
Old 02-08-2010, 09:49 AM
Thanks for the reply... next time I'll do the "key" thing and see what happens...
Old 02-08-2010, 10:35 AM
shadowkahn's Avatar
The starter not disengaging is normal. You don't have to hold the key till it starts. Just a quick turn and let it go, and the car will crank for 30 seconds, or until its started.
The not starting quickly is abnormal, of course, but your starter is behaving.
rockyboy
12-06-2022 02:29 PM
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
09-17-2015 09:01 PM
PortlandRL
09-14-2015 12:01 PM
Quick Reply: When Ign key is turned, starter turns but will not disengage
