What's wrong with my brakes?
I have oem pads that are 3 months old, nearly new oem rotors, and oem brembo brake grease on the pads. Sometimes randomly I get brake squeal under light braking, and only light braking. It's very random sometimes hot weather sometimes not.
Most times I find that under light brake pressure, the pads move ever so slightly within the caliper and cause the noise when rubbing on the caliper/piston. Under heavy brake pressure, the additional pressure holds the pads in place and no noise. Put some anti-squeal solution on the back, let it set up, reinstall and give it a try.
you may need some more anti-squeal compound on your shims/pads!
Stay Out Of the Left Lane
Received 1,236 Likes
thx guys, i thought something was wrong since all my parts are OEM so i was like "why are oem parts squealing?!"
so just wanted to confirm, we are supposed to grease the back of the shims, and between the shim and the pad right?
i just saw a thread in the 3g tl garage that the outer pad should be installed with the wear indicator facing downwards...i think i got that mixed up cuz my wear indicator is on the top...maybe that is where i messed up
acuratl26
04-23-2020 07:30 PM
GWEEDOspeedo
01-15-2016 10:39 PM
