Whats wrong with ittttt
Old 08-05-2010, 08:55 PM
05ACWHITE's Avatar
I have a 05 TL auto with 52k on it and im the second owner the first was my uncle....today i am driving it and all of a sudden when i hit the gas it doesnt wanna move and it feels like it doesnt wanna shift gears..then i stopped it nd shut it off and now when i drive it keeps like bouncing between gears like shifting up then down and if i put it in trip tronic i cant control what gear its in....like it will stay in 4th even if i down shift it.....anyone have an idea as to what it could be??? please help me...
Old 08-05-2010, 10:00 PM
YeuEmMaiMai's Avatar
time for a new trans from what you describe........
Old 08-05-2010, 10:02 PM
ScoobyZINE
AMUA6's Avatar
Agreed...
Old 08-05-2010, 10:22 PM
05ACWHITE's Avatar
Dammm thats nahhht goood.....what are the chances that Acura will cover it ?? i looked around on here and all i could find was that theres a 5yr/50k warrenty and that means im over by 1 month/2k...what should i do now??? sry for all the questions i just have no clue as to what i should do about it.....thanks for the help tho.
Old 08-05-2010, 10:23 PM
ScoobyZINE
AMUA6's Avatar
There is a chance they might goodwill it.. Meaning cover like 80% of the repair cost It's something like that, not real sure though.
Old 08-06-2010, 05:22 AM
Acura Cert MASTER TECH
acuratech239's Avatar
OP -
Since I have only the info that you wrote to go on (which wasn't bad, I just mean I can't check anything myself), something it actually could also be is a bad PCM. If you search on here, you'll find a decent amount of threads about 3G TL owners that got water in their PCM. This is usually from a clogged/plugged A/C drain tube (from the evaporator), and can be caused by many different things.
I have personally seen this on multiple occasions at work. Usually, it ends up causing misfire(s), and sometimes melts the coil(s) (I hate when that happens, so hard to get them out!). I have quite a few pics of fried PCMs, melted coil packs, etc.
Now, your thread caught my eye because I have one, and only one, 3G water damaged PCM that had trans issues. In fact, the tech thought it was a trans, which he replaced, only to have the problem still be there. On that car though (which I ended up having to diag and fix), it would free rev, while in gear, in 3rd or 4th, and just bounce of the rev limiter. Then it would be ok if you left off the gas, or tried to manually tap it down a gear.
I'm not sure how tech savvy you are, but removing your PCM to check for water isn't hard. You just need a 10mm and a Phillips screwdriver. It's located under dash, on the "hump". Pull back the carpet on both sides, unplug the connectors on the pass side, remove the two 10s (one on each side), and pull out through the pass side. Remove the four screws on top of the PCM, remove the lid, and look at the circuit board.
Or you could try blowing air up the drain tube and see if any debris comes out, or run your A/C and see how much, if any, water comes out.
Good luck!
Old 08-06-2010, 08:52 AM
LoveMyTL-S's Avatar
Check out this TSB:
http://techinfo.honda.com/Rjanisis/pubs/SB/B06-050.PDF
Your TL may still be in warranty.
Old 08-06-2010, 09:26 PM
05ACWHITE's Avatar
ok so i called Acura corp today and they told me to bring it to the dealership to have them check it out.....so i had to have it towed to the First Acura in Seekonk, MA and when i got there they tell me its $113 to even look at the tranny.....so i okayed it cuz theres nothing else to do and there going to call me tommorow and let me know whats wrong.... i pray to GOD its sumthin small but judging by my luck itll be a whole new trans
Old 08-06-2010, 10:23 PM
good luck with that...I hope acura picks up the WHOLE tab on that one
Old 08-06-2010, 10:53 PM
con5tant's Avatar
shouldnt this be under the powertrain warranty?
Old 08-06-2010, 11:31 PM
99accordguy's Avatar
was tran fluid ever changed ? keep us posted as to what the "stealer" says... i remember reading a similar situation and it was ACC sensor
Old 08-07-2010, 02:38 PM
05ACWHITE's Avatar
the dealer called back and said that it was the front pump in the transmission and it ruined the clutch pack nd everything in it...so there saying i need a new transmission but he couldnt give me a estimate til monday.....WTFFFF now what should i do next...should i go after acura seeing that it only has 52k on it???
Old 08-07-2010, 09:58 PM
plead your case to Acura Customer Service and hopefully they will help you out.....
without cracking the trans open, dealer really does not know why it would have failed. they prolly getting some low pressure readings and think it is the pump. Most likely internal filter got clogged, dropping pressure and toasted the clutch pack(s).
Acura dealer with quote you about $4.5k
Old 08-09-2010, 02:39 PM
05ACWHITE's Avatar
ok so its going to be $4,183.10+ tax for the transmission to be fixed and idk yet if Acura is covering anything.....i hope they help me out with at least 50-75% of it..... pleaseee god lol
Old 08-09-2010, 04:23 PM
speedytypes's Avatar
If it's milage ur worried about I'd just get it reversed, that is ofcourse if u haven't been to the steelership in a while
Old 08-10-2010, 04:13 PM
206tl's Avatar
Hmmmmmmmmmmm
Old 08-10-2010, 06:20 PM
this would be illegal and unethical to say the least
Old 08-10-2010, 06:25 PM
VQPower37's Avatar
the powertrain warranty is up to 60k ... so i think it would be covered under warranty?
Old 08-10-2010, 09:35 PM
e92 335i
ladiesman217's Avatar
u cant reverse digital speedos can u?
Old 08-10-2010, 10:58 PM
csmeance's Avatar
Received 2,016 Likes on 1,435 Posts
you can only rewrite the info on them, and that's only with the Honda Diagnostic system and can only be done on New Gauge Clusters. This is illegal and as well unethical as another member stated. Even if you did manage it and get a repair done, I'd like to think that Karma would soon lead you to shred something more than a transmission.
Old 08-13-2010, 10:09 PM
I'm Craig
cjTL's Avatar
Not to mention mileage data will show up on carfax reports.
Old 08-14-2010, 12:06 AM
ScoobyZINE
AMUA6's Avatar
And kharma's a bitch..
acuratl26
04-23-2020 07:30 PM
ttimberlak443
21
10-22-2016 10:23 PM
BrownBuck
NY/NJ
09-29-2015 09:53 PM
rangomango
California
09-24-2015 05:47 PM
Hines57
09-24-2015 01:58 PM
Quick Reply: Whats wrong with ittttt
