What is the whining noise from? power steering pump?
i've been hearing a whining noise from the car engine when i start up my car. and as i turn the steering wheel, the noise become more noticeable. is this noise coming from the power steering pump? sounds like i need my power steering pump replace...... can someone confirm on this or help me diagnose the problem?
thanks.
04 TL auto, w 127k miles.
thanks.
It's the o ring. The replacement will probably cost you less than a cup of coffee. You can do it yourself in about 15 minutes.
Check out this link: http://www.aboutacura.com/2007/12/ts...e-is-cold.html and let me know if this doesn't fix the issue.
thank you SS acura....that o-ring fixed it! i procrastinated till now to replace it, lol. if i knew it only took 10 minute, i would have done sooner. easiest fix ever! thanks again
I've had the same problem with the whining noise. As per this post I had my dealership replace the o-ring naff now it runs great. Think you for saving me more than a few bucks!
mike from annapolis
05-07-2017 08:21 PM
asahrts
09-04-2015 05:55 PM
