What are some 'issues' that you have decided to ignore?
2021 RDX A SPEC
Aside from rattles...
What are some issues that you've pretty much given up on and learnt to 'live with it'?
I've got a couple of rattles that I will address but i do have the:
1. moaning/whining when turning - most likely PS issue. Possibly o-ring although my VIN is not affected as per the TSB. (will perform a visual check to see if o-ring is orange)
2. https://acurazine.com/forums/3g-tl-problems-fixes-114/im-stumped-what-do-you-think-clutch-bearing-squeak-874200/ which is somewhat intermittent and might not even bother trying to figure out/diagnose or fix.
My driver side window doesn't automatically roll up with one click like the others, it stop half way, I have to hold the window button up to make it go up. Also since I've been driving lower I'm not as scare as before when I rub/scraping a little, it use to bug me like crazy since I wasn't use to it doing that lol.
Slot Machine Lubricator
I have LED switchbacks up front and LED signals in the back.
Sometimes when I'm turning right, the left front signal will fade-blink white while my right one will blink amber. And vise versa.
The correct side clearly blinks all LEDs up with amber, so it doesn't seem like a safety issue.
oops is that your face?
1. my tighten fuel cap warning light which comes on intermittently (pcv needs replacing)
2. when accelerating I get a very quiet noise that I cant really explain. it's like a rattle but not really I just can't find words to describe it lol. I believe it may either be fuel delivery or maybe an air intake noise
3G TL/2G MDX Owner
both bad side mirror actuators...i just don't use them.
the very subtle steering vibration most likely from torn LCA bushings...
the rest are some rattles and ticks.
popping noise from my navigation voice....alpine was $358 to fix a small problem. my navigation drive works completely fine besides that, so I leave the voice feature off and I never have to hear that popping noise.
LowNslowTL
let the list begin for me.. TONS of little lights out inside the car, cup holder slide cover broken, arm cushion worn out, need floor mats, rattle from my system, rattle from the visor area, clicking noise from the center console from take off and breaking, hood struts worn out, door dings out the ass. but hey im not complaining it has almost 200k on it
TLDude876
12-28-2016 03:18 PM
