What kind of oil leak is this?
Old 10-13-2016 | 11:09 AM
uneedkhoality's Avatar
Hello everyone, I had someone (acura tech side job) replace my front and rear valve gaskets last week and now I just noticed this leak. Can someone tell me what kind of leak it is? Thanks!
Attached Thumbnails What kind of oil leak is this?-img_3833.jpg   What kind of oil leak is this?-img_3835.jpg
Old 10-13-2016 | 11:12 AM
did you do the spark plug gaskets as well? looks like oil to me maybe he didn't clean it before re-installation. Is it fresh?
Old 10-13-2016 | 11:16 AM
didn't notice it when I picked up the car last week. yesterday is when I looked under the hood and noticed it. it is fresh oil. maybe I will have to check the spark plug. thanks!
Old 10-13-2016 | 01:22 PM
nfnsquared's Avatar
He shouldn't have touched the plugs for this job, but a plug could still be loose.
I'd wipe it clean and monitor it for a few days.
Old 10-13-2016 | 02:19 PM
you would assume so since he is an Acura tech, but i'll check the plug later today if I can. thanks for the advice.
Old 10-14-2016 | 10:44 AM
tenacious tl's Avatar
Could it also be the gasket for the spark plug tube? I know those gaskets can get torn up when removing and installing the valve cover. Or would that just cause oil to get into the spark plug tube and not leak outside of the valve cover?
Old 10-16-2016 | 01:50 PM
So i checked the coil and it's dry. Upon closer inspection, the leak is coming from the black thingy (with the single bolt) underneath the dipstick. Is it as easy as it looks as to removing that bolt and replacing the seal? Thanks!
Old 10-16-2016 | 07:30 PM
MarcDavidoff's Avatar
I was going to say it looks like the pcv valve is leaking. There is an o-ring that may be seeping. I'd get a new pcv and try that
Old 10-17-2016 | 09:37 AM
it's definitely leaking from the pcv valve assembly. so, is it as easy as I looks to replace it, just the one bolt? Should I replace the whole assembly or just the O-rings? thanks!
Fatfrii
06-10-2017 01:57 AM
joker11
09-20-2016 07:39 PM
New Car TL-S
04-29-2016 07:44 AM
deej0121
Integra
01-20-2016 11:29 PM
GK83
01-20-2016 08:02 PM
