What is this?
Old Sep 12, 2017 | 08:23 PM
stevemk07's Avatar
What is this?
08 base. Ive been noticing some clunking coming from fromt passenger corne. Replaced the end link which helped but there is still something making noise. I figure it is the shock and when I was taking off the strut bar I noticed this thing attached which i am guessing has something to do with the heater core? Anyway not as important as that it is just flopping up and down with only one bolt holding it in place.
Pics...
Notice the bolt attached to the strut bar in the lower right. That is the only one attached to anything other than the wires that come out of it.
Where does that other bolt attach to?
Old Sep 12, 2017 | 09:10 PM
nfnsquared's Avatar
app sensor. you're missing a bolt (red circle). Damn, lots of rust. Was that a flood car?
Old Sep 12, 2017 | 09:14 PM
Duronn's Avatar
That is very important
Old Sep 13, 2017 | 01:27 AM
stevemk07's Avatar
Not sure if it was or not. I dont think so... I purchased it from southern ontario w 200k kms after my old TL was totaled. Best deal I could find and it seemed to be in very good condition.
Ok i will see about putting it on there. Thanks.
Old Sep 13, 2017 | 02:54 AM
stevemk07's Avatar
Theres no hole there for a bolt to go in. Can you check yours and see if it is positioned right?
Old Sep 13, 2017 | 06:12 AM
salt did baaaad things to that car! wouldn't want to be the one working on it.
good luck on finding the hole.
Old Sep 13, 2017 | 09:18 AM
BreezyTL's Avatar
Where is it flopping around at?
Also, take some cleaner and a hose to that bay. Can't see what you are working on with all that dirt/dust in there.
Old Sep 13, 2017 | 11:30 AM
stevemk07's Avatar
Where second bolt is supposed to go but I didnt see a spot for it.... Will look again later.
Hard to keep it clean... Also not sure how to wash the engine bay
Old Sep 13, 2017 | 11:43 AM
BreezyTL's Avatar
Spray with some degreaser/cleaner, let it sit for a few minutes then spray out with a hose. Don't do it while the motor is HOT.
Did the bolt snap off inside of there?
Old Sep 14, 2017 | 02:51 PM
stevemk07's Avatar
Thanks for the suggestion. I may give it a try sometime.
As for the bolt location... It is there just buried under some rust...
I scrapes there area a little bit to reveal a bolt hole filled in with what I can only imagine is a broken bolt. Anyway I am not worried about it at all really.... I put some weather stripping over the hole location so the sensor housing is not banging against that spot. Tightemed the other one down and it seems sturdy enough.
Thanks for your help everyone.
Old Sep 14, 2017 | 03:21 PM
BreezyTL's Avatar
Spray it with PB blaster and let it soak. Drill into the the bolt and use a bolt extractor to remove the threaded portion of the bolt. Good Luck!
Old Sep 14, 2017 | 03:49 PM
losiglow's Avatar
I'm guessing you live on a humid island with dust storms.....
Old Sep 14, 2017 | 03:52 PM
stevemk07's Avatar
Lol right next to lake superior... I drive down dirt roads from time to time.
Old Sep 14, 2017 | 09:50 PM
GhostTL09's Avatar
How long have you had the car? I was originally thinking flood and now you say how great of a deal it was makes me concerned. Hope it's not serious.
Old Sep 14, 2017 | 10:07 PM
stevemk07's Avatar
Ok thats fine. The engine runs well and the transmission also functions well.
Old Sep 15, 2017 | 01:12 AM
stevemk07's Avatar
Ok fine! I will fuckin fix it
stevemk07's Avatar
Jk but i will
Old Dec 3, 2017 | 08:35 PM
stevemk07's Avatar
Alright I tried extracting this bolt today but it is not an easy location to put a drill amd I emded up breaking a bunch of bits to try and use the extractor. Anyway I am sure some of those bits bits are lodged in the broken bolt now. I actually had to do the same thing for tye Ram1500 just last week and that was successful but this time I am not so sure. HERE IS MY QUESTION: I am wondering if I can just drill into the metal just next to it and use another (smaller bolt and washer) to keep my APP sensor in place? What is under there and will I potentially hurt anything?
As it is I have been driving the car around for 2 years now and put on 60k kms. This bolt has been broken for a while now and I am looking into it more because my car threw an engine light this afternoon. I wonder if it was caused by this bolt or perhaps the APP sensor needs replacing as well since my obd2 reader gave me a p0741 code.
This is a mess but the info is there. Thanks!
Old Dec 11, 2017 | 01:41 PM
stevemk07's Avatar
No ideas as to whether I can safely drill next to that hole to secure the APP sensor?
Old Dec 11, 2017 | 02:22 PM
BreezyTL's Avatar
Slap some duct tape on it and call it a day. A broken bolt won't throw a code. P0741 sounds like the TC solenoid. Reaserch the fault code and find a resolution.
Old Dec 11, 2017 | 02:30 PM
Jk but i will
i lol'd! I get your humor!
agreed with breezy, the bolt wont cause the code to show up...rather maybe the app sensor is now dead and needs replacing
Old Dec 11, 2017 | 07:45 PM
stevemk07's Avatar
Now I am thinking I should be looking for weak or broken bolts everywhere else. Maybe my engine/tranny is about to fall out the bottom.
Old Dec 12, 2017 | 11:15 AM
I look at my engine bay periodically. and yes, thats exactly what I'm looking for, backed out or missing bolts.
just a quick glance for anything missing. sometimes i find my missing tool, or find missing bolts that need attention. always good to look and inspect
