What is this?
Old Aug 6, 2014 | 06:54 PM
recasares's Avatar
5th Gear
What is this?
Hi there I was replacing my shocks and springs today and saw this mount looking thing Thats broken? What exactly is it and how bad is it that it's broken? Thanks. https://i.imgur.com/EauHelr.jpg
Old Aug 6, 2014 | 07:02 PM
recasares's Avatar
5th Gear
Also if this belongs in the suspension section or anywhere else can you please move it.
Old Aug 6, 2014 | 07:32 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
Looks like a transmission mount . That looks to be way out.
Has ur car had major work done to engine or trans before? Or been in a collision.
That looks like its out an inch. So I would think something caused that to rip, that does not look like wear and tear.
Old Aug 6, 2014 | 09:00 PM
wojo1988's Avatar
2007 Type S WDP 5AT
^ what he said. That looks very bad
Old Aug 6, 2014 | 09:19 PM
Nick216's Avatar
The Boss
that happens when people slam into a curb. damaged sub frame aint cheap.
Old Aug 6, 2014 | 10:03 PM
EvilVirus's Avatar
OP do you feel vibration while idling or driving
Old Aug 7, 2014 | 08:20 AM
recasares's Avatar
5th Gear
The car has been hit before in the front. It has 190k miles on it. Also one of the engine mounts were worn apart I replaced it already. I was looking at the automatic transmission mounts for a 04 and couldn't find anything that looked like mine. If I found it would I be able to replace it or your saying that the mount won't line about because of a bent frame or something?
Old Aug 7, 2014 | 09:42 AM
recasares's Avatar
5th Gear
I found what it is. It's a suspension mount. Here's the part. http://m.ebay.com/itm?itemId=380715359807 But I still don't know if it will bolt in or not. The gap is too much and I don't know if I could bring everything together with a new mount.
Old Aug 8, 2014 | 12:49 AM
wojo1988's Avatar
2007 Type S WDP 5AT
Someone asked if you feel any vibrations while driving?? Do you
Old Aug 8, 2014 | 10:10 AM
recasares's Avatar
5th Gear
There's no vibration. Just a popping sound sometimes when i hit bumps real slow. The mount on the passenger side is still intact. I didn't realize it but there's suppose to be a bolt going through the center. I guess that fell out.
