Weird sound coming from engine
Got a weird noise coming from the engine. I don’t really know how to describe it even which is why I’m making a new post instead of googling it.
it only makes that sound on some cold starts, after engine is warm, the sound goes away. Sound is on the right side of the engine, towards the back. Would appreciate any advice, car is working fine other then that.
The following 2 users liked this post by peter6:
BlaccChino (08-03-2020),
Ted Kief (07-16-2020)
In my case similar sounds were caused by two pulleys. As far as I remember, at beginning the sound was only on cold engine and dissapeared when warmed up. Then it sounded all the time.
Not a car guy, so sorry if its a retarded question to ask, but im trying to learn all I can about the car.
Latent car nut
I just got the car from another owner and when I checked the CARFAX, it said that there was maintenance done to it, just didn't specific what kind. I'm just praying that it doesn't go out before I get to a tech.
no, more like a bunch of tapping or flapping, idk how to describe it. def not a whine. Posted video above on sound but here's the link again: https://youtu.be/MPeHxn_R8qg
I had this same problem. It’s one of you timing belt tensioners. I replaced both of mine and went ahead and changed my motor mount on the passenger side. Noise went away after changing. If it sound like the car is knocking get those tensioners replaced. The one that’s most important is the one with the pin on it that’s the one that really eliminated the noise
