Weird oil burning
Old Jul 27, 2020 | 11:54 AM
Robbym's Avatar
Weird oil burning
So I have a 2007 Acura TL type s. 108k miles with very good records. When I change my oil it doesn’t burn until about 2k miles on the oil and then it turns black and burns A lot oil. It’s fine when the oil is fresh though. Does anyone else have this problem?
burn as in you notice a decrease in oil? or..?
Old Jul 27, 2020 | 01:15 PM
smoke coming out of the exhaust?
Old Aug 9, 2020 | 04:37 PM
Robbym's Avatar
No smoke, I do get lots of black soot in my exhaust( although I have hfpc and not 3rd cat). The oil burning is getting really bad. It seems to happen when my oil gets black after 2k miles on the oil. I’m almost burning a quart a week and I drive an average amount. Although I do drive the car hard. Like very hard. I’m always flooring it and downshifting it. I think lots of engine braking can cause it to burn more oil because the engine is in a vacuum. I’m going to change my oil and see if I goes away. I also use 5w30 because I feel like 5w20 isn’t enough for the way I drive the car and how hot I can get the oil.
Old Aug 9, 2020 | 04:51 PM
still dont have no clue what you're speaking of..
instead of using the word burn, perhaps the better terminology is eat?
Does the car eat oil, meaning....its a quart low for example?
the color of oil has NO bearing on if the engine is eating or burning oil.
Some types of oil will get black, just like your example at 2K miles...
Old Aug 9, 2020 | 05:31 PM
Robbym's Avatar
I guess it eats oil. I have no leaks but I’m alway losing oil. My only guess is that it’s burning it. I have a new pcv valve and oil catch can and I don’t get much in my oil catch can.
Old Aug 9, 2020 | 06:17 PM
how much are you losing? How do you know you're losing oil?
Old Aug 10, 2020 | 09:58 AM
csmeance's Avatar
Try using some BG engine cleaner down the spark plug holes and that can clean up some carbon clogging the oil control rings if they are the issue causing oil burning.
Old Aug 10, 2020 | 01:34 PM
El_Cheapo's Avatar
bad PCV?
Old Aug 10, 2020 | 03:01 PM
Robbym's Avatar
About every week I have to add a quart of oil. One quart brings it back up to the top of the crosshatching on the dipstick and then a week later, it’s at the bottom of the crosshatch dipstick. I use penzoil 5w30 and I change my oil at about 40-50% oil life. When I was on 5w20 Mobil 1 I wasn’t eating as much oil but it did the same thing where it doesn’t consume a drop until about 2k miles and then it just starts eating oil but it wasn’t at this fast of a rate. Maybe about a quart a month on Mobil 1.
Old Aug 11, 2020 | 11:46 AM
El_Cheapo's Avatar
The first couple of checks that come to mind are:
  1. PCV
  2. Compression test
  3. Leak down test
  4. Remove valve covers and visual inspection
Old Aug 11, 2020 | 01:15 PM
Robbym's Avatar
I have a new pcv valve with a catch can too. Compression test wouldn’t be a bad idea. When I adjusted my valves, the engine has burnt oil on the inside and it’s only on the pcv side. I wouldn’t call it sludge, it’s such a thin film. My accord v6 has the same thing, non pcv side is super clean and the pcv side is “sludgy”. I change my oil very often and the lady who owned it before me changed it often with all the records to prove it.
Old Aug 11, 2020 | 01:30 PM
csmeance's Avatar
what oil filter are you using? Try pennzoil ultra plat in 5W-30 and see how it burns. How much soot is on your exhaust tips? Any smoke when you sit at redlights and go to move from the mufflers?
everything sounds normal, except for the loss of oil.
if no smoke on start up, I wouldnt think the engine was burning it past the ringland.
Old Aug 11, 2020 | 01:35 PM
Robbym's Avatar
I’m going to change my oil today to liqui moly 5w30 instead of pennzoil 5w30. If it keeps burning then idk. Maybe I’ll try switching back to 5w20. My oil is black and smells extremely burnt. Since oil gets thicker when it gets exposed to extreme heat, maybe that thicker burnt oil on top of using 5w30 is causing it to consume oil. I have no smoke on start up but I do get a lot of soot and sometimes black smoke out my exhaust for just a second when I floor it. But that problem started after getting hfpc and no 3rd cat.
Old Aug 11, 2020 | 02:01 PM
the only way one would get to the bottom of it is to tear down the engine to see where the fault is...
Perhaps head gasket?
perhaps ringland issues?
Old Aug 11, 2020 | 07:05 PM
If possible, post up a video of said driving style!
Old Aug 12, 2020 | 05:17 AM
Midnight Mystery's Avatar
Null and proud of it
Is it doing this?
Old Aug 12, 2020 | 08:28 AM
Ted Kief's Avatar
The oil control rings are toast sounds like your driving habits suck !!!
Old Aug 12, 2020 | 08:42 AM
Robbym's Avatar
Sometimes I’ll get black water out my exhaust. I’ve only had it happen when I drive the car and sit idling for almost 10 minutes and then revved it. It’s not much though. All of that started after I went to high flow pre cats and no 3rd cat though. I just changed my oil yesterday to liqui moly so let’s see what happens. I’ll keep y’all updated. Maybe it’s 5w30 causing me to burn oil once the oil gets burnt from the heat. After 2-3k miles on 5w20 it would burn Maybe a quart before I had to change the oil but on 5w30 it burns like a mofo.
Old Aug 12, 2020 | 09:08 AM
negative ghost rider, if you truly want to find the cause...the engine will need to be torn down and inspected to find out whats going on
Old Aug 12, 2020 | 02:50 PM
Robbym's Avatar
In this video you can see the soot that I’m talking about. The car was idling hot for about 10 minutes before I recorded this so there was a decent amount of water built up from steam which I think is kinda normal cause steam is a by product of combustion. No codes on the car and the lambda number is at 1.00 and sometimes goes to .99 or 1.01 so I know the car isn’t running fine. I changed the oil and I’ll keep y’all updated if it keeps consuming oil. If so I’m gonna try sea foam soaking the cylinders and new spark plugs.
Old Aug 12, 2020 | 07:14 PM
Simple answer. Carry a quart of oil and top off weekly. Simple. A little oil burning doesn't hurt anything.
Old Aug 12, 2020 | 09:56 PM
Robbym's Avatar
Keyword. “Little”
Old Aug 12, 2020 | 10:22 PM
Keyword. “Little”
How much oil are you consuming per 1K miles?
Old Aug 12, 2020 | 10:25 PM
Robbym's Avatar
Tbh I don’t even know. I just check my dip stick once a week and it’s a quart low. I definitely don’t drive 1k mikes a week. I just put fresh liqui moly the other day at 109,234 and I’ll check in with y’all at 110k or one quart of oil. Whichever comes first.
Old Aug 12, 2020 | 11:48 PM
If worst comes to worst, you can always get a junkyard J32A3 and throw that baby in.
Best bet is to just top the oil weekly and enjoy burning it out in the meantime.
Old Aug 12, 2020 | 11:50 PM
Robbym's Avatar
I would throw a j37a1 in. I wouldn’t downgrade from the j35a8 to a j32
Old Aug 13, 2020 | 02:49 AM
You got a TypeS?
Old Aug 14, 2020 | 01:51 AM
El_Cheapo's Avatar
If it has soot buildup at the exhaust, then it's getting in the cats. It's just a matter of time until they get clogged.
Old Aug 14, 2020 | 01:54 AM
Robbym's Avatar
I only have hfpc in terms of cats and no 3rd cat. The soot started right after switching to hfpc. And then the oil consumption happened a little later. From what I’ve seen on other threads, soot is common on the j35 as I’ve seen tls and RL owners complain about soot on the bumper and exhaust tips.
Old Aug 14, 2020 | 02:54 AM
Almost every car I've owned has put a little soot on the tips. My current Accord doesn't, but the RDX does a little. Haven't cleaned the tips in a few years though. My TL's tips were basically powder coated from soot. LOL. At one point, I thought they had been painted black.
Old Aug 17, 2020 | 01:41 AM
Robbym's Avatar
i was using a mobil 1 oil filter and 5w30 pennzoil ultra plat. once i used this oil the car started to burn more so i switched to just switched to liqui moly 5w30. No smoke on idle beside some tiny amount of steam depending on the weather and usually only happens when the engine is warming up. No smoke when normally accelerating but when i floor it, somtimes is get a some blackish smoke out the exhaust. This only happens when i dont floor the car for a while and then floor it. i think i have a bad oxygen sensor on my front bank. When i look at my secodary oxygen sensors, bank 1 and bank 2 have different readings. Bank 2 is also less consistant and just so happens to be the bank that had the cat break in half. lol. i think my cat blowing out damaged the oxygen sensor so Imma put new down stream and up steam oxygen sensors in and see if my soot and black smoke goes away.
Old Aug 17, 2020 | 05:00 AM
You say it only soots up when you floor it after driving conservatively for an extended period of time.... maybe carbon buildup?
Old Aug 17, 2020 | 11:25 AM
Robbym's Avatar
yea that’s what I was thinking. High amount of air flow blows everything out. But it still must be running rich for that much soot. And carbon build up.
Old Aug 17, 2020 | 02:12 PM
How's your MPG?
Old Aug 17, 2020 | 02:30 PM
Robbym's Avatar
How's your MPG?
20 mixed 16 city lol.
Those are the primary o2 sensors. They are giving different readings so I think they are starting to go bad. I’m going to replace them and see.
Old Aug 17, 2020 | 10:14 PM
Hows your A/F ratio?
Old Aug 17, 2020 | 10:32 PM
Robbym's Avatar
it says it’s running at 1.00 lambda or whatever which is good but I think the o2 sensor are lying and the car is actually running rich
Old Aug 18, 2020 | 01:35 AM
Yeah. I'd look into that further.
