weird clicking noise when i make a left turn!
Old 05-01-2010, 09:35 PM
F-SPORT
LTxArucAx60's Avatar
Hey acurazine, just recently i've been noticing this clicking noise, almost sounds like something is loose or something around the front drivers wheel area. I checked and found nothing hanging out or anything.
It only happens when i make a left turn. It will click a few moments and its gone. Sorry i dont know how to post sound clips. You guys think my brakes are going bad and need to replace asap?? Thoughts??
Old 05-01-2010, 09:40 PM
One on the right for me
subinf's Avatar
Axle?
Old 05-01-2010, 09:54 PM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
That, or control arm bushings, or CV joints. Take it to the bank.
Old 05-01-2010, 10:23 PM
OCD
Roger555's Avatar
sounds line a CV joint click which is part of the axle. Check to see if you have a ripped boot thats really the only reason your CV joints would be worn assuming you don't have really high mileage
Old 05-01-2010, 10:30 PM
Also, OP, you have to update your Custom User Title.
Old 05-01-2010, 10:37 PM
I'm Craig
cjTL's Avatar
I have this issue too...but mine sounds like it's from the steering wheel. My sister's 04 does it too. Hate it.
Old 05-01-2010, 10:41 PM
Too Fast TOO FURIOUS
enigmaos's Avatar
yeah, check the CV joints, control arm and axle.
Old 05-01-2010, 10:55 PM
F-SPORT
I got an appt with the dealership this coming wednesday so i am gonna have them check it out. Is this covered under warranty? I bought it in october, 2006. I have no extended warranty. The car has 32000 miles!
Other question it is 4 yrs 40000 miles i think so do i still have warranty till this october?
Thanks for your help acurazine!!
Oh i meant to change my custom user title some time now! thanks for the heads up princely!!
Old 05-02-2010, 02:01 AM
YW. Get on it, son!
Old 05-02-2010, 08:15 AM
enigmaos's Avatar
Make sure the dealer don't damage your wheels.
Old 05-02-2010, 11:34 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
dont count on axles covered at this age--seems like something they would 12/12 on you
look in your warranty book or acura.com
Old 05-02-2010, 11:36 AM
OCD
Roger555's Avatar
these no way an axle should be worn out at 4yr/ 40,000 miles!
Old 05-02-2010, 02:19 PM
01tl4tl's Avatar
its very easy to lose a cv joint early in rough roads, burnouts especially with wheels turned, or loss of grease by torn boot
Old 05-02-2010, 02:28 PM
OCD
Roger555's Avatar
I guess if you beat the hell out of it but typically I would expect at least 100K from an axle
Old 05-02-2010, 05:35 PM
CV boots and axles will also go out early if you're dropped.
Old 05-02-2010, 05:52 PM
ross7778's Avatar
I have the same sound on my 2005 with 46,000 miles. Mine only makes the noise when it's really cold though.
Old 05-03-2010, 09:12 PM
F-SPORT
Thanks again acurazine for your thoughts and comments. I am gonna swap rims for sure though. The lug nuts are duraluminum by rays. So if they use air compressed wrench it will damage them. And the dealership already messed up once by rotating my tires when i told them not too. Not gonna take a risk!! thanks again!!
Old 05-17-2010, 04:33 PM
F-SPORT
Oh man i was swapping rims yesterday and i found out that one of my wheels tpms sensor bracket has broken or came loose. Darn two piece wheels. But it turns out the noise was from that. So i have to take it to the tire place and have them uninstall the tire so i can see what is up!
02-25-2020 09:57 AM
gemz_acura
4G TL Problems & Fixes
15
09-26-2015 06:12 PM
PortlandRL
09-14-2015 12:01 PM
ptbarnett
3G RLX (2013+)
08-30-2015 12:39 PM
Quick Reply: weird clicking noise when i make a left turn!
