Water Leaking in Rear Tail Light?
Hello,
Wanted to know what your thoughts were or if anyone else has experienced this. I hope it is not a problem.
I noticed there is water accumulation around the black seam/seal that circles the left rear tail light. So far I have not noticed any water leaking into the actual unit or around the light bulb but just around the black 1/4 inch perimeter of the tail light unit.
On the right tail light, it seems tight and dry, with no visable water accumulation running along the black perimeter.
Is this a problem in the left rear tail light? Should this be replaced?? My car is brand new TL 08
thanks. D
thanks. D
Not its not normal and its not ok
This often occurs on the front lights on gen2 TL, and the same type seal/sealant is used on gen3 lights.
Back you go to the dealer with your list of items to be fixed- noises- speaker probs- make a list and take in for the recalls and problems
Oderint dum metuant.
The water gets into that part of all 3G TL taillights, but you can only really see it on the 07-08's because of their clear outer lense. In fact, they aren't actually leaking; there's a little crevice that runs around the outside of the taillight and water easily gets into it. As long as no water is in the actual light (inside that 1/4 inch trim area), you are fine.
RH - you wouldn't happen to know what they seal the taillights with, would you?
from d.c. to tennessee
i've seen that on my headlights before. I haven't taken them apart or anything to cause this but when I'm washing my car I can see soap accumalate behind what looks like a seal from the light to the actual car. Water has never got inside the headlight and they don't fog up at all. I think it is normal.
As long as the water only gets into the 2mm or so around the outside edge of the tailights you should be fine. Hard to see in the pic. The tailights are bonded together using a chemical reaction and the headlights are sealed using a silicone type glue. This is why the tailights need to be cut open to clear them and the headlights go in the oven.
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
