Washer fluid squirters
Old Dec 14, 2011 | 07:46 AM
myblack04tl's Avatar
My washer fluid use to shoot out just fine, now the driver side barley hits the windshield and the passenger side only shoots half way. I tried using some compressed air to blow it backwards in case it has some dirt built up but no luck. I then tried to take off the hoses but the nozzles are hard to get to. I was doing this in the dark holding a flash light but you have to take off a lot of stuff to get to the hoses. I will retry this weekend in the garage.
Any one have some tips?
Old Dec 14, 2011 | 08:14 AM
invalidalias's Avatar
pull the nozzles off and make sure that the fluid is coming out strong, if so, then sounds like you need to change out the nozzles
Old Dec 14, 2011 | 11:14 AM
It looks like the nozzles are built into the black trim piece that runs along the windshield. Has anyone ever taken this off?
Old Dec 14, 2011 | 11:48 AM
the nozzles are separate from the trim pieces. they wiggle in the slot. To remove one press them forward, toward the front of the car and then lightly pry the back side up and then wiggle it out.
SidhuSaaB
May 30, 2020 12:40 AM
LeVeL
Oct 18, 2015 04:19 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Cexarin
Sep 23, 2015 07:43 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
