Warped front rotors at 25k of mild driving, normal?
Old 01-07-2008 | 03:17 PM
Scott GN231's Avatar
I've done some searching and haven't seen a ton of posts about rotor problems on the 3rd gen TLs, but I have warped front rotors after 25k of driving (pads are less than half worn).
Dealer refuses to resurface or replace them under warranty. Seems very early to me on a car like this (it's not a G35 ) and I'm negotiating with them.
Comments? Experiences?
Saw that the rear rotors were redesigned in 06, but what about the fronts?
Thanks,
Scott
Old 01-07-2008 | 03:39 PM
Brettg's Avatar
Lots of people get warped rotors, I never get them on any brand car.
I dont let shops work on my cars, I use high temp grease on the disk to hub, and one the wheel to disk, and do up the lug nuts with a torque wrench in a do one skip one pattern to 80 foot pounds.
The grease aaids in heat transfer, and stops rust, the torque wrench prevents
over tightning, and the result is I NEVER get warped rotors.
Brett
Old 01-07-2008 | 04:08 PM
csmeance's Avatar
Brett
You can get warped rotors from excessive heat too, not just from having a bad tire installation. The TL has somewhat of a problem with warped rotors. What do you have, a 5AT or 6MT? Type-S? Depending on the model, there might be a TSB that can be dug up which will make acura resurface the rotors for free for you.
Old 01-07-2008 | 08:14 PM
Brettg's Avatar
I tend to brake late and hard, maybe its from riding the motorcycle, the wife and even the son tell me about it....
I have had a Jaguar XJ6, a Passat, the TL, the wife had a taurus, a lincoln LS V8, the son had a buick and a camry, only the taurus warped its rotors, three times, but since it was under warentee, my wife took it to the dealers.
After the warentee was up, I did the brakes, no more warping.
Three times in the first 30,000 miles, no warpage in the next 30,000 miles.
It works for me...
Brett
Old 01-07-2008 | 10:23 PM
I hate cars's Avatar
Thanks,
Scott
Mine warped after only 1,000 miles and no hard usage. I got the dealer to agree to do them under warranty after explaining that warped rotors aren't a wear issue.
Very nice choice in cars BTW...
Old 01-08-2008 | 12:36 AM
Bearcat94's Avatar
AZ Community Team
Scott check here:
https://acurazine.com/forums/showthread.php?t=170763
And here:
http://www.in.honda.com/Rjanisis/pubs/SN/B071000.PDF - Page 2, Lower Right
You might consider printing that PDF out and taking it to your Service Manager.
Old 01-08-2008 | 08:41 AM
BLACKURA_NY's Avatar
I have car ADD
My rotors warped badly @ about 22k-23k miles on a 06 5AT.... The entire hydraulic system on that car was f'ing shot.....
02-25-2020 09:57 AM
08 NBP TL
09-08-2015 08:49 PM
mav888
1G RDX (2007-2012)
09-08-2015 11:49 AM
asahrts
09-04-2015 05:55 PM
ptbarnett
3G RLX (2013+)
08-30-2015 12:39 PM
Quick Reply: Warped front rotors at 25k of mild driving, normal?
