VSA light + cant shift out of park
Old Dec 23, 2009 | 12:15 AM
dred87's Avatar
somebody help i am having this same problem! what do i do?
just got my airhorn and was honking it at some loser, then all of a sudden the horn went dead and the vsa light turned on. I turned off the car and when i tried to turn it on, the car would start but it wouldnt shift out of park! I also noticed that my brake lights are NOT turning on when i press the brake pedal...help
I called the place that did the horn and they said it was fuse #13 that controls all of that and is causing my problem, what u guys think is this true?
Old Dec 23, 2009 | 12:20 AM
Souljah's Avatar
Former Whiner
I think so. Look at the fuse box.
It just happened to my bro's RSX-S.
Horn and rear brake lights on same fuse. But his problem was an improper spliced wire blowing the fuse.
Old Dec 23, 2009 | 10:37 AM
01tl4tl's Avatar
not shifting out of park is a safety feature if the brake lights fail- it wont go anywhere
should be same as my gen2 but check your book:
To override- remove the small plastic piece on right side of shifter handle
insert car ignition key down and push in slot
Its now released- move shifter to N and hold brakes on
Remove key- insert key in ignition- start
get a dedicated circuit for the air horn-
or stop using it so much it overheats the wire and fuse blows~
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
BigJilm
Sep 21, 2015 08:32 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
