Vibration when gas is applied
Veeeee Tec
Hey guys,
I own a 2004 TL 6-Speed. Car currently has 142k on it. All maintence is up to date.
-Rims are straight.
-New tires.
-Balancing and Alightment completed.
To make a long story short: Couple months back, the car started shaking violently when gas is applied at 60 mph+, but when you let go of the gas and just cruise( there is no vibration/shaking). My buddy who is a mechanic.. looked thru the car and noticed a Tie rod end that was loose, so i bought a new one and the vibration is still occuring. Its driving me nuts and i need to get it fixed.
His next idea is Axles... what do you guys think?
Thanks in advance!
-Rims are straight.
-New tires.
Thanks in advance!
ABP_04TL (03-02-2012)
Veeeee Tec
I bought the car with 57k. I am no sure if they were ever replaced. I doubt it. if i replace them, i will do both already... just i am wondering what else it could be. Itll suck if i replace them and vibration will still be present.
The problem is that the joints in the axles are worn out. same thing is happening to mine now. theyll start to leak grease soon so get it fixed before you hear the clicking sound
3G TL/2G MDX Owner
axles been there, done that...mine went bad at 42k mi though. replaced at 50k. all is well again. vibration on low speed acceleration. inner CVs...clicking with turns....outer CVs.
Going in to day to have my Driver-side axle replaced (passenger-side done two weeks ago) and am praying that will fix this shimmy. Cant take it anymore!
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Some TLs have a vibration caused by the motor mounts. A new, improved style motor mount is available and should be used when the mounts are replaced. Check your mounts for tears. My 08 still has some vibration at 1300-2000 rpm even after the motor mount change. It's due to go to the dealer on Thursday for an oil change. I'll have them check the inner CVs while it's there. Hy
Veeeee Tec
I bought OEM axles from Acura. I wouldn't go AM...
My buddy that works at Lexus did the repair for me.... I am not sure about the bearing.. i just bought (2) brand new OEM driveshafts... The passenger side had a lot of play, so that was the cause of the severe vibration.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
