Vibration during braking
Old Dec 28, 2011 | 12:27 PM
nothome17's Avatar
Car starts to shake when I Brake. Is it the front or rear that causes the shaking?
Old Dec 28, 2011 | 09:49 PM
ohsixMTee's Avatar
Early Shifter
Usually it will be the rear that transmits vibration throughout the entire car. How do your rotors look? i.e. scored, lip on the outer surface? It is possible you have one or more warped rotors as well, are you a constant hard braker? Possibly a partially stuck caliper caused the warpage? You can measure the temperature of each rotor after a drive to compare and see if one or more are a lot higher than the others. Just a few thoughts, best of luck.
Warped front rotors usually start a shimmy in the steering wheel although if bad enough could very well transmit throughout the car. Nothing's impossible when it comes to cars. lol
Old Dec 29, 2011 | 07:27 AM
DMZ's Avatar
DMZ
Head a da Family
The odds are you have warped rotors in the front. Try to get them resurfaced.
The biggest cause of warped rotors on Hondas and Acuras is overtightened lug nuts. That's what happens when the air gun is allowed to spin them on until IT thinks they're tight. They're supposed to be only tightened to 80ft-lbs. Responsible garages use a torque stick which stops the air gun dead when the tightness reaches a specific # of ft-lbs.
Old Dec 29, 2011 | 09:46 AM
lilusadude's Avatar
An easy way to determine if it is the back rotors that are warped is to drive down the road and carefully apply the hand brake. This will apply the rear brakes only. If the car vibrates while doing this then you know it is the rear rotors that are warped and not the fronts. BUT, it is more common for the front rotors to warp as they are the ones that do most of the work when stopping the vehicle.
Old Dec 29, 2011 | 10:36 AM
imj0257's Avatar
Q('.')=O
+1 on guessing about warped rotors, in which case it is most probably the front.
Does it do it when braking at high speeds only or also low speeds too?
My guess is warped rotor. Also you might want to try lifting the front two wheels off the ground (same time or one at a time) and spin them and listen for any rubbing. If you hear rubbing or it isn't spinning smoothly it could be something with that wheel/rotor.
Old Dec 29, 2011 | 11:29 AM
nothome17's Avatar
Good info, thanks for all the feed back. Saves money to know which rotors are bad so I don't have to machine both front and rear.
If i get the rotors machined? Should I replace the pads if they are still good? Or is the pad still good from being used on warped rotors?
Old Dec 29, 2011 | 01:24 PM
Kikirra's Avatar
I believe the TL uses the inside of the rear rotor as a drum with seperate pads for our hand brakes. So applying the hand brake doesn't use the same rear pads and rotor surface as the regular brakes.
Old Dec 29, 2011 | 03:13 PM
spaceboy's Avatar
To my knowledge, if it's vibrates during braking it's always the rotor
and if it squeaks during braking then it's the pads, and all rotors can be re-serviced only once if never done before. but correct me if i am wrong....
Old Dec 29, 2011 | 04:16 PM
lilusadude's Avatar
You may be correct, I'm not sure. In that case, my method is useless.
Old Dec 29, 2011 | 04:19 PM
lilusadude's Avatar
The rotors have a minimum thickness spec. I'm not sure what the actual minimum thickness for the TL is but you can call an auto parts store such as NAPA to find out. The rotor can be turned any number of times as long as the minimum thickness requirement is still being met. All depends on how much run-out the rotors had before turning them. I think they recommend turning them when they reach .005" of run-out.
Last edited by lilusadude; Dec 29, 2011 at 04:20 PM. Reason: added run-out statement
Old Dec 29, 2011 | 05:01 PM
nothome17's Avatar
Can I use the same brake pads when I resurface the rotors? If the brake pads are still good.
Old Dec 29, 2011 | 05:02 PM
spaceboy's Avatar
^^ i don't see why not
Old Jan 3, 2012 | 08:14 AM
lilusadude's Avatar
Sure can. But, before reinstalling them, I like to take them outside and rub the pad on the concrete a bit. It will help knock the hard glaze off of the pad which will help reduce brake noise. Use the ol' "wax on, wax off" trick from karate kid with the pads on the concrete. Doesn't take much.
Old Jan 3, 2012 | 11:35 AM
usmarinedelta's Avatar
Are you sure?
The parking brake uses pads on the inside hub of the rotor, so if the op pulled the ebrake it wouldn't check the surface. I don't think it has anything to do with the rear braking surface on the front and rear side of the rotors if it makes sense.
Old Jan 9, 2012 | 02:25 PM
lilusadude's Avatar
Originally Posted by usmarinedelta
Are you sure?
See post #9^^^^^ I forgot the TL did this.... My bad. Must I apologize more for my mistake?? jeez... please read all posts before you attack somebody.
Old Feb 20, 2012 | 06:22 PM
jjcudak's Avatar
I have the same problem. I replaced the pads with OEM and resurfaced the fronts, and bought NAPA rear rotors. I would have purchased new OEM rotors if I knew how warped mine were (rears were way beyond re-surfaceable) but I was in the middle of the brake job when I found out :why me:. I again have the same vibration when braking; this time I am gonna give Brakemotive's deal a shot....front and rear slotted and drilled rotors with ceramic pads for $145. I know this sounds ridiculously cheap but people seem to like them. For the price I am willing to take the gamble and see if the extra cooling achieved with drilled rotors solves my problem. I hope you had/will-have better luck than me!
My
Old Feb 20, 2012 | 07:31 PM
3GTLCHICK's Avatar
I had the front causing a nasty vibration with the orig rotors. Replaced those with acura dealer rotors, same problem within months. My other half installed EBC rotors on the front, problem solved. I was told the material or prep was bad on the dealer rotors. When he put them on, he also sanded down something until it was clean. I don't remember what that's called.
Old Feb 20, 2012 | 10:36 PM
swoosh's Avatar
takin care of Business in
another thread on vibrations
here is my diagnostic tool:
1> Vibrations when braking at high speeds: Warped rotors
2> Vibrations when driving between certain speeds: Balance issues, Bent rim, bubble in tire, axle, hub-centric rings
3> Vibrations when at a stop: Vac line, mounts
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
