Vibration at 60mph?
Old May 9, 2009 | 02:09 PM
Mal4ishka's Avatar
Cool Vibration at 60mph?
New Frame, tires, ballance, alligment and i feel vibration from floor @ 60mph?
Axcel? any ideas?
Thanks in advance
Old May 9, 2009 | 03:10 PM
WantTwoRun?'s Avatar
SICK SSM
i have bad Vibration at 60mph also... but in my steering wheel
Old May 9, 2009 | 08:03 PM
Turbonut's Avatar
Although an out of balance condition usually is the worst 65-75MPH, I would make certain the wheels/tires are balanced on a Hunter Road Force machine and also check for a bent/damaged wheel, out of round tire, or even a tread that's separated. It's best to try and isolate the corner of the car that is affected e.g, switch tires around to see if the vibration changes.
Not knowing what repairs were made on the car, I would check the axles for damage e.g. bent. Usually in a FWD drive car, any damaged motor/trans mount, or slightly out of square frame, the axles with CV joints are very forgiving, unlike U joints on a RWD vehicle.
Guess you've got to go by elimination.
Old May 9, 2009 | 08:54 PM
Mal4ishka's Avatar
ill take it back to the dealer on monday, i am crossing my fingers
Old May 10, 2009 | 03:42 AM
chinesestunna's Avatar
bent rim? hit any potholes lately?
Old May 10, 2009 | 07:20 AM
Dave_W's Avatar
Bent rims sounds logical. Happens a lot with these 3G TL's. While CV joints are forgiving, believe it or not that ended up being the answer to the vibration problem once on an 02 TL that came in with the same problem. The used car mechanic tried everything he could think of, then finally after a few days, one of the other A techs helped him out and rebuilt the axle. Fixed the problem. Good luck.
Old May 10, 2009 | 07:30 AM
Turbonut's Avatar
Let me clarify, forgiving in the respect of angle, and you are correct, not a worn out cv joint, but the worn joints normally indicate a vibration on acceleration, and not cause a vibration at a specfic speed.
Old May 10, 2009 | 09:23 AM
Jesstzn's Avatar
A lot of times feeling it on the floor indicates it is coming from the rear wheels.
Swap the left rear with the left front and see if the symptom changes .. if not then move the right side ... doing this can help isolate if its a wheel problem and which wheel.
Other alternate is to replace one rear wheel with the spare and drive it .. if still the same then put the wheel back and replace the other rear with the spare etc.
Old May 10, 2009 | 08:56 PM
Mal4ishka's Avatar
Thanks, Before i go to a dealer im going to put my buddies wheels on and take it for a spin. That should indicate weather its the wheels or not
Old May 13, 2009 | 10:20 AM
Mal4ishka's Avatar
All problems Resolved!
The Tireshop never informed me of a bent rim i had, and they put on my new tire backwards which was setting off my allignment
Now ill get a new rims (or the set) and ill be worry freeeeeeeeeeee
Old May 13, 2009 | 11:07 AM
TeknoKing's Avatar
Мальчишка,
And where did you find this genius shop? lol McDonald Ave?
Old May 13, 2009 | 08:03 PM
Mal4ishka's Avatar
Originally Posted by TeknoKing
Мальчишка,
Yeah and Z
Old May 13, 2009 | 11:46 PM
Damn these TL rims, I had a bent one too
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
