vibrating when braking
Registered but harmless
Received 1,149 Likes
No, it's not normal-- it sounds like you have at least one slightly warped disc/rotor; it's often correctable by turning/machining if the discs/rotors have enough material still on them.
Hm.. I have the exact same problem as well.
If I brake harder than normal (normally I slow down to a stop) depending on the situation, I notice steering wheel starts to shake (vibrate).
Storm, please let us know what the dealer says.
If you have a pulsation in the brake pedal you won’t need to wait to see what the dealer says. The only question would be, is the rotor to be cut or replaced. If the pulsation is minimal, chances are that the rotors can be turned and still be within the factory minimum thickness, but if the feel is very heavy, or the rotors are scored, the rotors will need to be replaced along with the pads.
You can also warp rotors just with normal use .. not just the over tightened lug nuts ... If the car was put away with hot brakes the pads will insulate a portion of the disc so it doesn't cool evenly .. thus a warp.
This is more common if your in mountainous country and your destination is near the bottom. Your brakes don't get to cool before you shut down.
Be careful about turning the rotors. Sometimes the dealers don't do such a good job. My car has 17500 miles and I am on my second set of pads and third set of rotors. Took the dealer a while to get it right. Car initially had rust ridges in the brakes when I bought it, that's why I have had to replace so early.
Yes, they can search the Forum, but some people don't consider the member's thoughts on a subject a vaild answer.
Similar to this thread, as you recommended using the proper torque to tighten the lug nuts to help avoid the out of tolerance condition, and what was the next reply:
"i don't think i understand how that relates? if you over-torque your wheels...that can warp your rotors?"
Head a da Family
I'm sure the majority of the time the job is done correctly. I was just saying that I have had a bad experience in the past where I still got pulsating from the brakes after having the rotors lathed. What you said makes sense.
Acuras and Hondas are notorious for warped rotors. They went to semi-metallic pads to enhance high speed braking and to reduce fade, which means they had to go to a softer rotor. The rotors are thin to save unsprung weight, which makes them prone to warpage. You can only cut them once, then you have to replace them. I am tired of it and next time plan to find after-market rotors that resist warpage.
MrHeeltoe
20
02-23-2023 01:54 PM
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
