Valve cover advice
Old Jun 12, 2023 | 10:44 PM
LazLong's Avatar
N00b Extraordinaire
Question Valve cover advice
Hello folks. I've got both an '05 and '07 TL with leaking valve covers that I plan on repairing soon. I'm wondering if there is anything else I should replace while I'm in there? e.g., when I replaced the valve cover on my '08 Sequoia, there were a couple of gaskets (cylinder head gaskets #3 and #4)) and oil control valve filters that were either a) non-reusable and not included in the FelPro valve cover gasket kit, or b) readily accessible and if needed replacement or cleaning in the future would require much of the same work to be done again. Like replacing the water pump when you do the timing belt, etc.
Basically, I'm looking for advice on what I can replace while I'm in there.
Thanks!
Old Jun 13, 2023 | 06:25 AM
Superunknown's Avatar
Tube seals and bolt grommets. Use OEM.
https://www.oemacuraparts.com/v-2004...-head-cover-06
Part #1 is a kit for one bank.
Old Jun 14, 2023 | 09:43 PM
LazLong's Avatar
N00b Extraordinaire
Thanks, and for the link as well. I guess I should have listed what I already had in mind; I consider plug seals and valve cover gaskets as integral with the new-fangled plugs-through-the-valve-cover design. First time I replaced plugs in a plugs-through car I freaked out at the oil on the plugs not immediately realizing it wasn't a big deal, just leaky tube seals.
OculiAquilae
Nov 25, 2015 09:48 PM
mars
Dec 7, 2012 01:15 PM
AznHonda
Jan 26, 2010 03:30 PM
pimpstaman90
1G TL (1996-1998)
Apr 28, 2006 09:35 AM
