Valve adjustment ?
Also, did you see the video posted by ericthecarguy.com? The link is in the Problems forum. So far, he's only posted part 1 which covers getting to the valves, but not adjusting them. Part 2 is not out yet, but hopefully soon.
I figured I'd have to remove that strut bar anyway. I've practically removed that damn bar than removed my seat belt.![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
Thanks for the info on the video. I'll definitely scope it out. I have the official Acura manual, but it's always nice seeing it done in person(or by a person on a video).
I figured I just did the timing belt and whatnot, and I know you're supposed to check the adjust the valves at the same time.
nfnsquared how were your valves, did they need a lot of adjusting or were they pretty much in spec?
Thanks, I'm quite surprised how out of spec your valves were. I'm hoping mine aren't too bad, but I also have almost zero valve train noise. Just a little noise from my power steering pump before it warms up. So, it looks like that might be my next replacement part.
I don't think you read that post correctly. They were only out of spec by 0.001"...
One thing I wish I had done and which you may want to consider (depending on what trend is observed):
Since my exhaust valves all showed a tendency to close, I wish I had set the clearance to 0.012" - 0.013" instead of 0.011" - 0.012".
Here are some pics and info of when I did mine. Admittedly, there isn't a great picture of the accessibility to the rear valves. I don't remember it being a big issue though.
https://acurazine.com/forums/3g-tl-2004-2008-93/valve-adjustment-pics-854094/
crbnfbr (10-18-2012)
https://acurazine.com/forums/showthread.php?t=854094
crbnfbr (10-19-2012)
be careful putting the rear head gasket cover back on. its easy to damage the spark plug seals when putting it back on the rear due to the weird angle and lack of space to work with. Oil them up an carefully put the head back on. use ur fingers to make sure no part of the spark plug seal is pinched by the spark plug tube.
I'm super impatient, and I got bored. I didn't want to have to wait to have the valve cover gaskets shipped to me. So, I decided just to take off the plenum and put the P2R gasket on. I know it's been said I could more than likely re-use the valve cover gaskets, but I'm the type of person that if I'm gonna do it, I'm gonna do it right. Oh, it was nasty in there too. I went through two cans of carb cleaner to get it looking brand spankin' new.
One thing that sucked though was I set my 1/4" torque wrench to 8ft/lbs(it's supposed to be 8.7ft/lbs), and all three of the front "upper cover" bolts just kept spinning. So, now I'm gonna have to keep an eye out to see if there's any oil that leaks from there.
What do you guys suggest I do with those three bolts, tap it the next size up or use helicoils?
i did that to one of my bolts, just kept spinning, I said screw the torque wrench and did it by feel.. Now i'm just hoping for no oil leaks too. I guess try some head gasket sealant as well?
