Urgent! Help!
Old Jan 20, 2016 | 06:54 AM
ericcdong's Avatar
Urgent! Help!
Hey acurazine,
I just went to check my oil level and I tugged on the dipstick too hard and this resulted in the dipstick tip snapping off (the indicator where it tells you the level), so now that whole flat panel is stick within the engine. All I have now is the stick with no indicator head. Will this cause my engine to mess up????
I'm afraid now and I'm not sure what to do???
I couldn't find past posts on this so I'm guessing I'm like the first to do this. Please help!!
Old Jan 20, 2016 | 07:11 AM
Jakes_tl's Avatar
So your saying that the tip of you dip stick is in the oil? If that is the case whatever you do DO NOT start the engine. I would drain the oil and see if it comes out and if not pull down the oil pan and you should be able to get it that way.
Old Jan 20, 2016 | 08:01 AM
rockstar143's Avatar
Jake...it's not gonna get sucked into anything or travel a foot up into the actual combustion chamber.
You're fine, you'll just never be able to check your levels. I'd leave it in there and just put the top part back on.
Or remove the valve cover and see if you can grab it with some pliers.
Old Jan 20, 2016 | 09:15 AM
nfnsquared's Avatar
^^^^^Yeah, I'm no expert on oil flow, but I think that is correct. Just buy a new dipstick and enjoy life
But I'm dying to know how the end got sheared off....
You could drain the oil and try to fish the end out by sticking a magnetic probe in the drain plug hole... It's just sitting somewhere on the bottom of the oil pan...
Old Jan 20, 2016 | 09:18 AM
Didn't you read the OP, he hulked it when he pulled out () and broke the tip ()
Old Jan 20, 2016 | 09:20 AM
guitarplayer16's Avatar
Old Jan 20, 2016 | 09:22 AM
Unfortunately, if i can read properly, he's saying the tip broke off as in where the oil is read..?
Old Jan 20, 2016 | 09:24 AM
ah correct i read it wrong
Old Jan 20, 2016 | 12:09 PM
GKinColo08TL's Avatar
If you get a drain plug that is magnetic (made for BMWs and I imagine for Honda/Acura also) then the tip should stick to the drain plug at some point and then you can remove it.
Old Jan 20, 2016 | 12:32 PM
I still feel like that end of the tip isn't the one that could have broken off. Dong is strong, but c'mon...that doesn't even make sense.
Old Jan 20, 2016 | 01:00 PM
nfnsquared's Avatar
Yeah, I still don't understand how Dong broke off his dipstick Dong
Old Jan 20, 2016 | 01:06 PM
even he doesn't...
Old Jan 20, 2016 | 01:07 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
I wonder what the ladies will think with a broken dipstick.
Old Jan 20, 2016 | 01:09 PM
the shy virgins won't mind it...
Old Jan 20, 2016 | 01:32 PM
ericcdong's Avatar
Y'all slay the shit out of me 😂😂😂
Basically my car was in the garage and so I had to stand on the driver side to pull the dipstick. Since I pulled it from the side, it initially didn't come out, so I had to pull it hard and then it came out with the tip broken off.....
Yeah call me an idiot I know....
Mechanic says it'll be 20-70$ depending on how long it takes to get it out. Should I just suggest to wait it out or take it out ASAP?
Old Jan 20, 2016 | 01:48 PM
nfnsquared's Avatar
Ah, the ol' sideways pull out? Not recommended, as you now can see
Heck, for $70, I'd be tempted just to let someone else do the dirty work. Is he going to drain the oil?
Old Jan 20, 2016 | 01:57 PM
for 70 bucks, might as well make him do the oil change too
Old Jan 20, 2016 | 02:14 PM
I'd pay 70 for that...
Old Jan 20, 2016 | 04:59 PM
MarcDavidoff's Avatar
I would try sticking one of those telescoping magnets down in e dipstick hole and see if by chance you can snag it. They are like an antenna so pretty thin and should fit down the hole
Old Jan 20, 2016 | 05:27 PM
i bet dipstick end is coated aluminum and not magnetizeable
Old Jan 20, 2016 | 07:05 PM
blueracer17's Avatar
I was beginning to wonder how long it would take for somebody to make this observation.
Old Jan 20, 2016 | 07:06 PM
truonghthe's Avatar
how the hell he manage to broke that piece off the cable?
Old Jan 20, 2016 | 07:41 PM
Just checked- the cable is steel and a magnet sticks nicely
Old Jan 20, 2016 | 07:57 PM
is the tip too?
Old Jan 20, 2016 | 08:16 PM
Originally Posted by paperboy42190
I dont understand why people are saying to use a magnetic or drain the oil. isnt only the handle part of the dipstick broken off? As in the rest 2 feet of dipstick stuck at the dipstick hole? The for sure way is to remove front valve cover and pull it out that way.
I think he's saying he broke the tip off aka the last two inches or so
Old Jan 21, 2016 | 07:25 AM
I wish I had 2 inches to break off. But naw...that would only leave me with 1.
Old Jan 21, 2016 | 06:16 PM
nfnsquared's Avatar
Yeah, the dong is not magnetic. Good catch. If any of the wire shaft was left inside the dong, it will be magnetic on that end. Otherwise, you're SOL with a magnet...
