Type S replacing clutch and FW, what else?
Hey, I finally got my LuK flywheel and I'm looking to have it and the clutch replaced at a local shop. I can't tell if the motor mounts need to be replaced to not. But I figure its a good time to replace things while it's all apart and I'd like to have the parts available to avoid extra downtime. Any suggestions on what else I should replace while the motor is out? 07 with 80k miles
I would assume that the pilot bearing and clutch release bearing are also in the change, but I'd examine/check clutch hydraulics, mounts, CV boots, clutch fork, spring, ball, seals, etc., but certainly wouldn't throw new parts in that didn't appear in need of replacement.
First of all I'm the 2nd owner and only put 10k miles on it. Secondly the friction is fine, it's the self adjusting feature that gets screwed up mostly on high RPM shifts resulting in a moving engegment point/stiff pedal to the point where I wasn't able to get it out of gear once using the clutch
Skirmich
09-15-2015 06:41 PM
