Trying to remove Power Streering Bolt
Old May 3, 2011 | 10:02 PM
drbk563's Avatar
Hello,
I have an Acura TL 2007 Type S. The issue I have is that I am getting the squeaking sound coming from the power steering. I have been trying to remove the bolt the connect the hose to the engine but I have not been able to. Can anyone suggest a tool that can fit in this tight space. Attached is an image of the bolt I speak about.
Thank you,
http://postimage.org/image/m5o6weys/
http://postimage.org/image/m5rhz3yc/
http://postimage.org/image/m5ut1sxw/
Old May 3, 2011 | 10:07 PM
DimwitRj's Avatar
that ONE RED tl
I believe that's the hose where the o-ring that gives people problems is located. I changed out my o-ring and iirc I used a 10mm closed end wrench to loosen and then my fingers to get it all the way out.
Old May 3, 2011 | 10:22 PM
drbk563's Avatar
How long was the 10mm wrench?
Old May 3, 2011 | 10:34 PM
DimwitRj's Avatar
that ONE RED tl
Just a regular 10mm maybe about 4-5" long just to break it loose.
Old May 4, 2011 | 01:47 AM
paperboy42190's Avatar
^+1 it was easy, takes 3 min
Old May 4, 2011 | 02:22 AM
SpiderX1016's Avatar
10mm Box-End Wrench. No trouble taking it off.
Old May 4, 2011 | 10:05 PM
drbk563's Avatar
I will try again. What I found difficult was that fact that the space is very tight to maneuver.
Yikes
May 3, 2021 04:29 PM
cycdaniel
Dec 17, 2019 10:58 AM
ghuns
Sep 16, 2015 04:26 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
darksky
Sep 5, 2015 03:11 AM
