Trunk Spring Broken 2007 TL
Yesterday I found out that one of my trunk springs amd the clip had broken. This is a base model with navigation.
Some questions:
1- How can you tell if it is the right spring or the left spring? The broken part has the big hook on the Right side (passanger side) but I think the part is the Left Spring.
2- None of the dealers carry this part in the DFW area but they say it is at a local warehouse. Is it possible to go there and pick it up? Dealer price is about $30.00 and I am sure they want a chunk of change to put it on.
3-There seems to be some confusion as the part number does not seem to match or available is many places. (74872-SEP-A01)
4- Anyone in the area with the spring tool willing to help out?
Some questions:
Now that the trunk is fixed, here are the findings:
Where the small U shape hook attaches to, that is the correct side.
They will not let you pick up from warehouse
There is a new part number: (74872-SEP-A01ZZ) Cost ~ $14
Ended up letting the dealer do it for $25.
I can isntall trunk springs myself...however does anyone know of any stronger trunk springs for the TL? the type s has an extra decklid which makes the stock springs kinda weak and the trunk never pops up too much. and I have it on the stiff setting alrdy
Search the vendor sites for the OEM wing spoilers and there might be a separate part number for those springs; otherwise search AZ threads for the wing spoilers and references to the trunk springs.
Trunk opens weakly
I just purchased a 2007 TL, and the trunk is rather weak in opening. Sometimes It doesn't even raise, it just releases the latch. Is there anything I can do to fix this? Can the springs be adjusted? If not, is is possible that they are just old and need to be replaced? If so, is it something I can do myself?
Jul 16, 2017 07:33 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
