Trunk light is flickering off and on
Old Jan 6, 2012 | 09:14 PM
yila95's Avatar
hello guys,
trunk light on my 05 TL turns off when i open the trunk lid all the way and might come back on its own. The light also flickers if i swing the trunk lid. anybody knows the problem is? Thanks
Old Jan 6, 2012 | 09:38 PM
Bearcat94's Avatar
AZ Community Team
Do you have an aftermarket light/LED in there? If so, it's probably going out or it's not secure in it's socket.
If it's an OE bulb (or OE style bulb), it's probably not secure in it's socket or it's going bad.
Old Jan 6, 2012 | 10:41 PM
yila95's Avatar
It's the original bulb, I will check the bulb first. Thanks
Old Jan 7, 2012 | 10:26 PM
yila95's Avatar
just find out that the flickering trunk light triggers the car alarm. can a bad bulb cause that?
Old Jan 10, 2012 | 09:59 PM
yila95's Avatar
checked the bulb and fuse, they are good. there is no voltage when the light is off according to a volt meter. any body has the same problem? thanks
Old Jan 10, 2012 | 11:29 PM
SpiderX1016's Avatar
Switch the bulb with one of the interior bulbs and see if it still does it. I think they're different wattage but it should work.
My guess, the connector.
Old Jan 15, 2012 | 10:19 AM
yila95's Avatar
same thing, its the power got cut off when i swing the trunk lid or shake the cable that attached to the driver side trunk hinge.
Old Jan 15, 2012 | 12:53 PM
swoosh's Avatar
takin care of Business in
check ur trunk switch....it is the switch which tells "trunk is open" hence the light comes on.....
if ur bulb is properly in the slot like it should be then i would blame it on the trunk switch....
Old Jan 17, 2012 | 09:08 PM
yila95's Avatar
Are you talking the trunk release push button under the dashboard?
Old Jan 17, 2012 | 10:12 PM
swoosh's Avatar
^^^ no the one in the trunk....lemme try to get a pic of it tomorrow....
its like your door switch, basically tells if your trunk is open or close....another way to check if the switch is going bad is:
if your inside your car, does the "trunk open" indicator go on randomly ?
Old Jan 18, 2012 | 09:44 PM
yila95's Avatar
Thanks!
no, "trunk open" indicator is normal.
does your trunk release push button light up? mine doesn't
Old Jan 18, 2012 | 10:10 PM
swoosh's Avatar
^^^ no it doesnt light up, but when your trunk is open is does display in the MID....
damn so the MID is fine so am guessing the switch is working fine
do the lights flicker when your trunk is open or close ?
Old Jan 20, 2012 | 10:24 PM
yila95's Avatar
the light flicker when the trunk is open, especially if i swing the trunk lid up and down. i am guessing is the bad wires, but i don't think the trunk light wire is attached the trunk lid thou. what do you think?
Old Jan 20, 2012 | 10:27 PM
swoosh's Avatar
^^^ correct the wire is not attached to the lid, but they are all "zip-tied" at some point
darn it, i did try everything cudnt troubleshoot this one
Old Jan 23, 2012 | 09:55 PM
yila95's Avatar
Thanks Swoosh. i will try to find the wires when the weather gets better.
Old Jan 23, 2012 | 10:12 PM
swoosh's Avatar
^^^ not a problem dude....
but yeah, if you get in ur trunk and start taking the insulation/carpet off, you will find the issue
Old Mar 20, 2019 | 04:11 PM
Edipiano's Avatar
I’m having this same problem with my 07TL. Were you ever able to pinpoint/fix the problem ?
mada51589
Jan 9, 2025 04:40 PM
Ol'Dave
Sep 5, 2020 02:56 PM
handsom-hustla
Nov 13, 2015 05:04 PM
PortlandRL
Sep 14, 2015 12:01 PM
Phambam12
Sep 6, 2015 06:57 PM
