Trunk Button does not work. I searched!!
Old Aug 13, 2007 | 09:42 AM
Status45's Avatar
I install a NeoIonAUx ipod connector. Now everytime I want to open my trunk I have to turn off the engine and press the fob button. The wires behind the button are all good and the mirror controls and VSA off button work fine. It's just the trunk. Could it be a fuse or something? The button in the glove box isn't turned off either. Please help me somebody. It could very well be I didn't connect something right.
Old Sep 4, 2007 | 12:47 PM
sherwin991's Avatar
04 Abyss Nav, 07 KBP TL-S
Open your glovebox, look for the trunk lockout switch in there. You probably hit it when you were installing your iPod connector.
Old Sep 14, 2007 | 06:01 PM
Skelly's Avatar
You might have your car accidently set for valet security. That happened to me once. Check in the glove compartment and see if your switch is set for that security. If so, you can only open the trunk with the key fob. Read the manual and it will explain in detail.
Old Sep 14, 2007 | 10:21 PM
Mlauderdale1000rr's Avatar
2010TL, 07 600RR, 06 1KRR
+1
Old Sep 22, 2007 | 07:11 AM
Aznpersuasion's Avatar
Supercharged 2005 TL NBP
+2
Old Sep 22, 2007 | 02:34 PM
meburdick's Avatar
'17 RDX Tech AWD - WDP
Come on, people! Did EVERYONE not read that part?
Old Sep 28, 2007 | 01:43 PM
rshanahan's Avatar
07 TL-Navi 5AT, NBP
Double-check the wires on the switch in the glove box. When I removed mine (glovebox) to install my DICE, the cheap valet switch fell apart. It was, thankfully, easily put back together. On mine the wire was not long enough and pulling the glove box down put enough stress on the switch to have it come apart.
The switch must be closed (shorted) for the trunk to operate soooo, if the switch got boogered it might be your problem if you removed the glove box for your installation.
Hope this helps.
Old Nov 19, 2007 | 01:26 PM
ajeetm's Avatar
Thank you guys. I had this same issue and it was because someone accidentally flipped the valet switch - which I didn't even know existed. You guys rock, I love this forum!
mada51589
Jan 9, 2025 04:40 PM
AndrewS
19
Mar 14, 2024 06:59 PM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
VA2000TL
Oct 2, 2015 08:26 AM
PortlandRL
Sep 14, 2015 12:01 PM
