Trouble Turning over (starting)
My '07 TL has 43k miles and just starting weirding out on me this morning. Thought I might check the battery this afternoon.
Problem-All electronics flicker several times as the car turns over when starting. It takes longer to turn over. Not sure if it's relevant to the problem, but now the Autofeature in the driver window doesn't work. Still operates but doesn't have auto up/down. Safety mechanism (letting me know there's an issue)? Not sure.
If anyone has any suggestions or has had this problem please let me know.
Registered but harmless
Received 1,149 Likes
BTW, your battery may still be under warranty.
If it's still a full replacement at your TL's age & mileage, get the dealership to change it out.
If the battery is at the prorated stage, just get a battery from Costco or somewhere.
Welcome to AZ.
It was the battery, but that presents another problem Turbonut... The battery was stickered with 08/08 by the manufacturer. That battery probably isn't even 2yrs old. I had the alternator checked and it's fine. Think there might be a direct short somewhere, but have no clue where to start looking. Any thoughts?
The other possibilities are loose battery cables (check them-- the car/ground cable and the positive post clamp seem to get loose) or perhaps a marginal alternator which is not recharging the battery.
G/L.
I'd replace the battery if you haven't already. I replaced my OEM battery (8/08) with an Interstate a month or two back. Hasn't given me any problems.
If a fully charged battery just dies overnight, have someone do a Parasitic Draw test.
rockyboy
08-04-2024 10:35 AM
bearingman07936
01-07-2016 03:22 PM
