Trouble taking control arm off
Attempting to take my lower arm off but I'm stuck here how can I get this off I already took the bottom screw off I guess it's rusted on there good whatre my options? In photo 2 it's bottom left
ball joint separator..?
no, that's not right, that's to remove the ball joint,, have you tried jacking up the knuckle rotor while using a pry bar to pry the arm down?
The fork tool on the right (listed under summit) will separate it, but usually ruins the boot/seal around the joint. If the seal is damaged, I would replace the joint
yeah looking at his first pic.. i'd say the boot is a tad ruined
Yeah I'd like to go ahead and change that part out as well while I'm at it what piece is that and hopefully my dad has somthing similar to that metal wrench so I can pop it out
username123
08-02-2016 02:40 PM
Joe Lui
04-11-2016 05:12 PM
