trouble codes
Old Aug 19, 2006 | 07:32 PM
StYLeZz101's Avatar
trouble codes
P0161
P0300
P0305
P0306
the following codes came up when i hit the front y-pipe for the exhaust on a man hole cover...where the road was being re done....for all you wid dropped cars in the new york area dont not take the service road to the LIE comin from van dam st... the man hole covers are really high and do some bad damage...although it doesnt even seem like they are...i was done like 10 mph holdin up traffic and stll got damage done...should i try callin 311 and explain what happened and see if they would like help foot the cost of repair?
Old Aug 19, 2006 | 08:15 PM
bhelsdon's Avatar
The last three codes are misfire codes, I am not sure about the first one. 300 random misfire, 305 cyl 5 misfire, and 306 is misfire on cyl 6.
Old Aug 20, 2006 | 08:19 PM
Greg-ster's Avatar
P0161 Front Secondary Heated Oxygen Sensor (Secondary HO2S) (Bank 2, Sensor 2)
Heater Circuit Malfunction
Old Aug 20, 2006 | 10:15 PM
StYLeZz101's Avatar
thanks for the responses...i hope by replacing the damaged pipe all the codes will be cleared...
Old Aug 22, 2006 | 09:07 PM
StYLeZz101's Avatar
P0161 Front Secondary Heated Oxygen Sensor (Secondary HO2S) (Bank 2, Sensor 2) Heater Circuit Malfunction..............this sensor would be the one circled in red???
Old Aug 23, 2006 | 07:01 AM
bhelsdon's Avatar
Bank 2 is actually the pipe comming out of the front of the engine. so it would be # 11 on your diagram. Bank 1 is on the back of the engine. Bank 1 is always on the same side as cylinder 1.
Rear
1 2 3
4 5 6 This is how the TL cylinders are numbered
Front
Old Aug 23, 2006 | 02:19 PM
StYLeZz101's Avatar
Rear
1 2 3
Front
thanks a lot for this information...i wanted to be sure what sensor i had to order...
Jamus22
Jun 11, 2023 10:08 AM
08KBP_VA
Oct 22, 2019 01:55 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
