Transmission upgrade
Old Nov 24, 2017 | 09:58 AM
Shannono's Avatar
7th Gear
I bought an '04 TL with a bad automatic transmission. I can find '04-'05 transmissions on car-part.com for $900 - $1,000, but '06-'07 transmissions are $250 - $500 all day long. I found an article last week that talked about the newer transmissions having a lot of the known issues resolved, but I can't seem to find the article again. For those in the know, is there any reason I can't use the newer transmission to get this car going again?
Old Nov 24, 2017 | 11:09 AM
horseshoez's Avatar
Latent car nut
A few comments:
  • The 2004-2006 TL Automatic transmissions are the same and subject to low reliability.
  • The 2007-2008 TL Automatic transmissions are upgraded and quite reliable, however, they will not fit in your car as the Engine/Transmission interface has changed.
  • The 2006-2006 Honda Accord V6 (often referred to as "AV6") is upgraded as well and will bolt right into your 2004 TL.
Old Nov 24, 2017 | 11:46 AM
Shannono's Avatar
7th Gear
Thank you for that info. Was that supposed to read 06 - 08 Accord? Is there a transmission computer that needs to be changed at the same time?
Old Nov 24, 2017 | 01:42 PM
horseshoez's Avatar
Latent car nut
No, only the 2006-2007 Accord. Search AV6 in the 2nd Gen TL forum; there is a very long thread on the subject.
