Transmission Replacement
Old Feb 2, 2014 | 08:12 PM
ahmed1231's Avatar
5th Gear
Yesterday the transmission on my 04 TL automatic blew and I'm looking at replacing it with an 07 TL Type-S transmission I found a deal on.
My question is, will the 07 type-s transmission work okay with my 04? I know people have had success with 06-07 Accord transmissions on 04 TL's, so I'm assuming a TL Type-S transmission should work fine.
The seller says it is compatible with 07 base which has the same J32 motor, so it should be compatible, right?
If anyone has any information on this, I would appreciate your input.
Old Feb 2, 2014 | 08:34 PM
bbergero1181's Avatar
two different trannys for two different engines. The Type S has the 3.5 liter engine and a beefier tranny from the RL I don't believe you can bolt it up to the 04 base 3.2 liter engine.
Old Feb 2, 2014 | 08:47 PM
ahmed1231's Avatar
5th Gear
But the Type S and the 07 base model share the same transmission and the base 07 is a 3.2 as well.
Would I be better off rebuilding my transmission than replacing it?
Old Feb 3, 2014 | 04:50 PM
ahmed1231's Avatar
5th Gear
Can anybody confirm that the 2007 Type S transmission will not work on a 2004 base TL?
Old Feb 3, 2014 | 05:12 PM
YeuEmMaiMai's Avatar
no go... totally different unit
Old Feb 3, 2014 | 05:51 PM
paperboy42190's Avatar
yes its true the 07 tl share the same automatic transmission for base and type S, but there are very minor differences in engine between 04-06 and 07-08 base TL's.
point being, dont get the 07 transmission unless you're willing to shell out big bucks to make it work
Old Feb 3, 2014 | 06:17 PM
ahmed1231's Avatar
5th Gear
Ah... Alright. 2007 transmissions seem to be much easier to find and cheaper. Guess I will keep searching for an 04-06 trans
mada51589
Jan 9, 2025 04:40 PM
bnaritomi
Feb 17, 2016 03:22 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
carz0159
Sep 20, 2015 06:11 PM
asahrts
Sep 4, 2015 05:55 PM
