Transmission popped - what happened?
05-6MT-TL
was out driving around, pulled up to my driveway and put it in reverse, started to back up and heard (and felt) a loud pop and then nothing. I first thought it popped out of gear and so I just put it back in reverse and tried again and nothing. The clutch pedal feels normal but there is absolutely nothing transferring to the wheels. So I tried first gear and the same, nothing! I tried other gears and nothing there either. Clutch pedal felt fine and shifting felt fine. it was then I realized that I could put it in any gear while the car was running without even pushing in the clutch. it was as if I had the clutch pedal pushed all the way in the whole time. No grinding sounds or anything. I kept trying different things including shutting the car down and restarting and continue shifting trying different gears when suddenly it wouldn't go into 5th gear. I tried a couple of more times and it went back in and I could hear a very quiet spinning sound that sounded like it was coming from the transmission. The sound would go away if I pushed in the clutch and come back when I would disengage the clutch. I am baffled at what is going on. it doesn't make sense that everything feels normal and I can shift gears while the car is running. Its like the clutch is stuck disengaged. I can logic it being stuck engaged but not the other way around. I think there is something to learn from the 5th gear situation I described above but its not helping me. Any ideas what's going on and how I can diagnose this. BTW - original trans with 236K miles. Pressure plate, clutch and bearing replaced at 155K. They were not wore out but I had the transmission off at the time and so I just replaced them.
I believe if you didn't replace your flywheel, it may have torn up your new clutch. I believe member DMZ had that happen.
duckengine (01-05-2016)
axle snap? broken spring on clutch (defect)?
05-6MT-TL
05-6MT-TL
no symptoms at all. just got home (lucky) after driving around for about 45 minutes. Was backing up very slowly, letting the clutch out very slowly when it "popped". here are a couple of pics showing where it sheared.
Last edited by duckengine; 01-10-2016 at 09:46 PM. Reason: pics won't insert...don't know why
I just had the same thing happen.
Was in Drive, then about to make a left turn and then POP... vroooom... but not going anywhere.
Luckily some nice dudes were able to push me to a parking spot in my building.
The engine was spinning but my shifter wouldn't engage. While I was pressing the gas, i could hear something rotate and go clunk clunk in tune with accerator.
I hope it's just a half shaft or something minor.
Looks like corrosion caused the shaft to weaken under the damper. Lots of salt on the roads during winter in Michigan.
