Transmission not engaging
#41
So I've fallen victim to transmission issues as well. 05 TL with original trans at 128K mi. It catches the gears a bit roughly at cold starts but loses the 3rd 4th and 5th gears when it warms up. Its had 3rd and 4th pressure switches replaced in Oct 2011 and recently had 3x3 service with Redline D4 8/2013 to 12/2013. Never replaced the filter. Dealership says that I gotta replace the trans for $4500, but I was wondering if you guys thought that gettin the filter and pressure switches replaced and drain and fill would be a good final hail mary? Or should I just do the filter and drain and fill?
I don't think you're supposed to use Redline in cold climates
#42
I'm at 124,00 miles. I just dropped almost 3 grand on a full tune-up (2 motor mounts replaced, spark plugs and cables, timing belt and tensioner, water pump, power steering pump, both front compliance bushings, and 4 wheel alignment.
After all this was done, I had the car for about a week and my tranny started doing the same exact thing as the OP. There are no codes on the dash and the tranny was due for a flush soon. Did I wait too long?
I cranked it up yesterday just to keep the parts lubricated and the transmission was making a terrible whine. When i put it in gear, it delayed for a few seconds and then it slowly slipped into R and D. The whine only occured in P or N. Any suggestions?
It may be time to get the transmission replaced.. It won't be much longer until it throws a code.
Mine threw P0746 - Stuck A/T Clutch pressure solenoid A.
Replaced the solenoid, filter, 3rd/4th gear switches and a full 3x3
Drove beautifully the first time, next day after it warmed up it began to slip again..
#44
Wow. You can also only use Redline in black cars. It won't work in other colors.
#47
Hey guys, AT 06 with 102k. Last night I was doing my normal service of redline racing atf 3 quarts every other oil change so it stays fresh. After the the drain and fill I turn my car on to go for a drive its starts to whine, never heard this before, I shut the engine off to check everything but nothing I can see was wrong, so I turn it on again and same noise comes up and this time I came of park to reverse the noise stopped but trans DID NOT ENGAGE! I then tried drive absolutely nothing engaging the car is stuck in a neutral sense but only whines in park and neatral. It was cold in the garage like 20°f I'm thinking the oil is not very good in cold weather. I then drained it noticing no metal on magnit bolt but start seeing little clumps of a jelly type fluid at this point I'm shitting my pants. I always keep up with my trans since I got the car at 43k redline oil, pressure switches and filter change. I then checked the other bottles of redline racing atf I have and open it to find these very little jelly like bubbles in the fluid every single bottle except the light weight racing atf was jelly like ! I didn't catch it when I filled it and now I think my transmission is done because of some old or expired redline oil I bought in a 12 pack on not very long ago on amazon. Im calling redline tomorrow to express my situation in hopes of some help.
Just the cap of brand new bottle of redline racing atf. captured some jelly
The last drain i did after i put the rest in open bottles to dicard notice the bubbles of jelly like form
#49
śïιέит вµт đέαđιý
Gotta bring this post back to live as I believe my car is possibly coming to an end.
I have a 04 TL with 235,000km on it. I maintain it very well. About 2 years back my car had a hard a time kicking into the 3rd gear and I got my 3rd and 4th gear pressure switches changed and since then I've been doing a tranny fluid change every other oil change using Acura/Honda ATF.
The fluid level is normal and its a light brown color, so that part seems good.
I do not recalling ever changing the transmission fluid filter. For some reason no one has ever mentioned anything about that to me. Guess, its kind of stupid of me for not knowing this. At this point I'm hope its that.
But right now the car is pretty much what the OP's car did.
I do not have a engine light or D blinking or anything. I was driving the car and all of a sudden it just started revving to about 3000RPM without giving me any actual power. Then it I would release my gas and the car would drive fine again. By the end of the car the problem got worse and the car fully stopped moving and it would just rev. I noticed when you switch the car from Park to Drive the car usually just moves forward on its own without me having to push the gas down, but with this issue it wouldn't even do that. So I parked managed to park my car in a parking lot and toe truck came and he moved the car and obviously the car drove fine. So he decided to let me drive my car as he followed to the shop (7km) and I didn't have any issues, but I left it there anyway for them to take a look at it.
Is my tranny gone? Why would the car sometimes drive and sometimes screw around? Filter clogged?
The the symptoms I told my mechanic over the phone he said its probably dead :S But he has to take a look at it tomorrow.
#50
It's those Damn external filters!
#51
06 Acura TL transmission replace
Hi guys new to the group, was curious if you guys could help me. So i have an 06 Acura TL, and the torque converter clutch went bad so i bought an used trans from eBay. Of course i did my research spoke to the guy it was pretty legit got my trans in a couple days warranty , low mileage. I got my mechanic to put it in the car, and seems like its worse. The car barely accelerates now majority of the time just revs instead of accelerating & when it does accelerate it takes it a min to get up to speed. Also when i move the gear from say “P” to “D” or “P” to “R” doesn’t matter what i have it in I.T still indicates or lights up beside the “P” as if i have it in Park. Guy i bought it from says just need to clean solenoids and make sure i strictly use trans fluid from the dealership. Any ideas what could be wrong thinking my mechanic did something wrong or maybe it is the trans... any idea?
#52
#53
Can't fugue out how to post my own problem with transmission
My transmission engages fine at startup. After it's going it will stop engaging motor is running but nothing .I pull over shut down and restart it and it's fine. Never heard of this problem before and it does it frequently. Since it clears as soon as I restart and put it in gear, doesn't sound like a transmission but what could it be
#54
Welcome to the forums.
If you want to submit a new thread, near the top left corner of the page there is a box that says "New Thread" except in the Car Parts or Cars for Sale Black Market forums where it says "Create new marketplace listing". If the box isn't there, you are probably in a forum where you are not yet allowed to submit threads, like the Black Market.
Click on that button and you get a big yellow outlined box where you can type your message and put in the thread title.
When you're done with that, go to the bottom and there are two boxes, "Submit new thread" or "Preview post". It is always good to click on the "Preview Post" button and check out what you wrote.
After you make any corrections, or if it was okay as is, click on the "Submit new thread" button and it should enter your thread.
If you want to submit a new post in an existing thread, go to the bottom of the thread and post your comments in the Message Box, and then click on the Post Quick Reply button when you are ready to submit.
#55
soo... no one figured out the problem?? anyone change there tranmission filters and/or clean there solenoids ...and recieve good results?? Im assuming No while Hoping fro the best!!!
#56
Maybe overfilling the transmission... I have an 08 and notice now that it is sensitive to that... In fact I would now err on the side of caution and underfill rather than overfilling.
#57
5th Gear
It just happened to me.
Leaving work, about a mile down the road, doing 35 in a 20 zone, the car went from 3 or 4th gear down to first. And would do the typical revving. Shut off and back on it would engage in drive but only first, would not go into 2nd. Cold start it would shift out, then nothing.
#58
Latent car nut
#59
What would be the latest version for my 3rd and 4th gear at pressure switches?
I see there are at least a couple of options for part numbers. I ordered 28600-RAY-013 and 28610-RAY-013 for my 2004 TL. It is my understanding that these are the updated versions for parts 28600-P7W-003 / 28600-P7Z-003 ?
#60
#62
Latent car nut
You forgot to out the drain plug back in?
Handbrake is pulled up to the 9th click?
Car still on the hoist?
Two bro-trucks are using your car for a tug of war?
A semi truck pinned your car against a concrete wall?
I'm just guessing...
IcouldsleepnmyTL
06-17-2011 06:56 PM
