Transmission Fluid Change - Need help
Old Apr 30, 2014 | 02:51 PM
kocyk123's Avatar
Hello,
I am creating separate topic since I have read so many opinions on ATF change that I got all confused. I recently bought 2007 TL with 57k miles on it. I want to change the ATF and somebody recommended replacing pressure switches. Could somebody tell me exactly what I need to get to do this service? What kind of fluid and how many switches are there? Thank you in advance!
Old Apr 30, 2014 | 03:12 PM
cam_2's Avatar
Originally Posted by kocyk123
Hello,
Look in the garage under C-025 and C-026 to replace the fluid:
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
Keep looking in the garage under A-110 to replace the switches:
https://acurazine.com/forums/3g-tl-2004-2008-93/110-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2004-2006-a-729149/
Old Apr 30, 2014 | 04:36 PM
Due_Diligence's Avatar
You have an 07 so I believe there are 3 switches
https://acurazine.com/forums/3g-tl-2004-2008-93/110-b-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2007-2008-a-840630/
Old May 1, 2014 | 11:50 AM
cam_2's Avatar
https://acurazine.com/forums/showthread.php?t=840630
Good catch, thanks
Old May 1, 2014 | 01:27 PM
kocyk123's Avatar
Thank you gentleman for your help! I wanted to get this done ASAP and ended up at the Stealership... Got my fluid drained and filled. Tranny feels smoother
Old May 2, 2014 | 08:37 AM
mada51589
Jan 9, 2025 04:40 PM
cobra10363
Jul 23, 2024 04:13 PM
nanos
Nov 12, 2015 08:41 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
quake97
Aug 30, 2015 07:57 PM
