transmission click?
Old Apr 30, 2006 | 01:10 PM
csmeance's Avatar
transmission click?
hi,, i have searched threads and could not find what I was looking for. When I push the brakes while in park to switch to reverse or any other one, my clutch makes a clicking noise. This happens when the car is hot and cold. Do you guys and gals think this might be realted to my Knocking engine? (therad is in problems and fixes)
Old Apr 30, 2006 | 01:13 PM
SouthernBoy's Avatar
Registered Member
Park? Clutch? Which do you have.. a manual or an automatic?
Old Apr 30, 2006 | 02:46 PM
csmeance's Avatar
i have anautomatioc and for future refrence, i have a flat driveway and also the car is parked in a two car garage with only the TL in it. The garage is also flat
Old Apr 30, 2006 | 03:48 PM
Registered Member
Firstly, has it always done this? I would suspect that it is just the drive train slack being taken up by engine torque being routed through the transmission. Remember, with automatics, there is always going to be some torque delivered to the drive wheels at engine idle speed when the transmission is in gear. So if you go from, say, Drive to Reverse, or the other way around, the slight bit of slack, or play, in the rest of the drive system, including the CV joints, will be taken up. This sudden take up of slack can and most often does, emit a sound.
Old May 3, 2006 | 04:18 PM
csmeance's Avatar
i also got this problem check out by the dealship and he said it was the transmissions engaging so the clutch/gearshift thing moves a little, so that is the click, thanks for the responses.
Old May 3, 2006 | 06:28 PM
BustedJack's Avatar
The Boss
^ it's normal buddy. It's when the transmission is engaging against the gears and sometimes it makes a little noise. Not any problem
knight rider
Mar 4, 2016 08:59 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
thegipper
Sep 28, 2015 01:01 PM
